jeongbyungheon When I set the EERROM XY value and use it later, the setting value changes again every time. The aspect ratio also changes after printing. What could be the problem? Repetier-Host V2, 1,6
Repetier In Repetier-Firmware the xz scaling is part of the transformaton matrix. So make sure transformation is enabled and that you did not run any command resetting the matrix like autoleveling. Also when you set it with a gcode save it explicitly to eeprom and not set it temporarily.
