I downloaded and used the latest version of Repetier-Host, with Slic3r, 1.0.6, and today went to print 2 copies of a pad in one go, with no skirt and 3mm brim; the first brim printed out fine, but when it went to print the 2nd, it went to the X home position of the bed, printed a line from the 2nd part, then went to finish printing the brim of the 2nd part, only it was shifted about +3mm X further from where it was supposed to be. I tried separating the parts more and moving them around the bed, but it does the same thing. When I let it run with the shift, it went back to the 1st part for the infill and it was then shifted the same amount. What's up? Using an Airwolf 3D 5.5. All previous versions have never had this problem.
