archprlest I have a i3 clone with a melzi board. Using 0.92.9 I have the x_min_pos -40 and y_min_pos -15. When homing x and y the printhead moves to end stop and stop. Sending gcode to move x and y to zero takes print head to front left of build plate. How do I get the printhead to hit end stops and move to zero during homing of x and y?
Repetier Easiest way is to set xy min to 0 and instead set <p class="p1">ENDSTOP_X_BACK_ON_HOME 40</p><p class="p1"> </p><p class="p1">ENDSTOP_Y_BACK_ON_HOME 15</p><p class="p1"></p>
archprlest Well count not find out to set that using gcode or the config tool on line. But located it in the source and it worked after adjusting max x and y. Thanks, now off to configure the z probe and bed leveling.
