I'm using the Repetier server Pro 1.4.18
When I send the G-code using Prusa Slicer to any of my printers and then press "pause print" on the Prusa printer control panel, the printer pauses, but doesn't remove the nozzle from the model. The main issue is that there is no "resume print" in the control panel menu, only "stop print". I can only resume the print from the print server. I saw the exact same issue on other forums, but with the Octoprint server. The suggestion was to add a custom event dependent G-code command for "run on pause" and "run on continue". I tried M601 and M602, which didn't work. When I tried using M25 and M24 instead, it kinda worked, but stopped working the next day. I cannot control all printers through the print server, because the printers are in a shared workshop, and the server is only for the admin. Other people should be able to pause and resume the print on the printer panel while sending the G-code from the Prusa Slicer via Repetier Server.
Printers:
Prusa MK3 (firmware: 3.14.1 ), MK3S+ (firmware: 3.14.1), and MK4 Inputshaper (firmware: 6.2.4).
