lol, that didn't work, made it way off, I did find however just adding resistors in series that it matches within 2-5 C between 170 and 235 when I have a 220 ohm resistor in series with the thermistor. That's much better than 100 C off, but still, would liek to understand how I could tweak a table in order to make it work better.
Edit: More like 5-10 C off, it starts 10 off at 170 C then is 5 C off at 200 to 235, but then after that the temperature goes way up while I am still reading like 250 or so, but the ext temp is actually 260.
