<font face="Arial, Verdana">hey,</font>
Firstly thanks for the advice previously, using the configuration Tool i was able to fix the mirroring problem for the Y Axis.
But I was hoping to ask for some advice, hence the post here.
I am using the Repetier 0.92.8 Firmware.
Printing from Repetier Host every works perfectly.
Printing from SD Card the Bed overheats.
When Printing from the SD Card, the temp rises to about 95 deg, instead of the GCODE 60
The interesting thing is that the Display shows the temp as being 95deg, and how it should be 60 deg.
As this does not occur when i print using Repetier host, this makes me think that it is a Firmware setting, rather than a mechanical/electrical problem.
As i am using a relay to run the heatbed, so i have been using the setting;
#define HEATED_BED_HEAT_MANAGER 2
<font face="Arial, Verdana"> #define HEATED_BED_SET_INTERVAL 5000</font>
Sample below of the firmware settings, as far as i know this is all stock standard....
#define HAVE_HEATED_BED 1
<font face="Arial, Verdana"> #define HEATED_BED_MAX_TEMP 110</font>
<font face="Arial, Verdana"> #define SKIP_M190_IF_WITHIN 3</font>
<font face="Arial, Verdana"> #define HEATED_BED_SENSOR_TYPE 1</font>
<font face="Arial, Verdana"> #define HEATED_BED_SENSOR_PIN TEMP_1_PIN</font>
<font face="Arial, Verdana"> #define HEATED_BED_HEATER_PIN HEATER_1_PIN</font>
<font face="Arial, Verdana"> #define HEATED_BED_SET_INTERVAL 5000 </font>
<font face="Arial, Verdana"> #define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80</font>
<font face="Arial, Verdana"> #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME 196</font>
<font face="Arial, Verdana"> #define HEATED_BED_PID_IGAIN 33</font>
<font face="Arial, Verdana"> #define HEATED_BED_PID_DGAIN 290</font>
<font face="Arial, Verdana"> #define HEATED_BED_PID_MAX 255</font>
<font face="Arial, Verdana"> #define HEATED_BED_DECOUPLE_TEST_PERIOD 300000</font>
<font face="Arial, Verdana"> #define MIN_EXTRUDER_TEMP 150</font>
<font face="Arial, Verdana"> #define MAXTEMP 275</font>
<font face="Arial, Verdana"> #define MIN_DEFECT_TEMPERATURE -10</font>
<font face="Arial, Verdana"> #define MAX_DEFECT_TEMPERATURE 290</font>
thanks in advance.
