I'm totally stumped. Using Pi4 with gpio uart to SKR Mini V1.2 connected to rxtx in TFT pins. Fresh install of Repetier-Server and Marlin. Repetier quickly connects to the printer and if I'm fast I can sneak in some commands myself as well before it disconnects. Using USB cable everything works well but I want to use uart to make cabling more tidy inside the case.
I have tried every combination of DTR/RTS settings, using baud 115200. Below is example terminal output, it functions the same regardless of DTR/RTS settings. Connection is made but then it's terminated for some reason.
Mesg:3:57:02.376: Dtr: false Rts: false
Mesg:3:57:02.382: Connection started
Mesg:3:57:02.382: Printer reset requested - emergency:false
Mesg:3:57:02.398: Dtr: true Rts: true
Mesg:3:57:02.418: Dtr: false Rts: false
Recv:3:57:02.423: Response while unconnected:echo:Unknown command: "echo:Unknown com: "e"
Recv:3:57:02.423: echo:Unknown command: "echo:Unknown com: "e"
Recv:3:57:02.423: Connection verified by:ok
Mesg:3:57:02.423: Received extra ok - ignored
Recv:3:57:02.423: ok
Send:3:57:02.423: N1 M110
Recv:3:57:02.426: Line: 1
Recv:3:57:02.426: ok (N1)
Send:3:57:02.439: N4 M115 ; Get firmware capabilities and info
Recv:3:57:02.462: FIRMWARE_NAME:Marlin 2.1.3-beta3 (Jul 3 2025 14:43:58) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 Pro KINEMATICS:Cartesian EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv:3:57:02.464: Cap:SERIAL_XON_XOFF:0
Recv:3:57:02.466: Cap:BINARY_FILE_TRANSFER:0
Recv:3:57:02.468: Cap:EEPROM:1
Recv:3:57:02.469: Cap:VOLUMETRIC:1
Recv:3:57:02.472: Cap:AUTOREPORT_POS:0
Recv:3:57:02.473: Cap:AUTOREPORT_TEMP:1
Recv:3:57:02.475: Cap:PROGRESS:0
Recv:3:57:02.476: Cap:PRINT_JOB:1
Recv:3:57:02.478: Cap:AUTOLEVEL:0
Recv:3:57:02.479: Cap:RUNOUT:0
Recv:3:57:02.481: Cap:Z_PROBE:0
Recv:3:57:02.482: Cap:LEVELING_DATA:1
Recv:3:57:02.484: Cap:BUILD_PERCENT:1
Recv:3:57:02.486: Cap:SOFTWARE_POWER:0
Recv:3:57:02.488: Cap:TOGGLE_LIGHTS:0
Recv:3:57:02.491: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv:3:57:02.493: Cap:EMERGENCY_PARSER:1
Recv:3:57:02.496: Cap:HOST_ACTION_COMMANDS:0
Recv:3:57:02.498: Cap:PROMPT_SUPPORT:0
Recv:3:57:02.499: Cap:SDCARD:1
Recv:3:57:02.501: Cap:MULTI_VOLUME:0
Recv:3:57:02.502: Cap:REPEAT:0
Recv:3:57:02.503: Cap:SD_WRITE:0
Recv:3:57:02.506: Cap:AUTOREPORT_SD_STATUS:0
Recv:3:57:02.508: Cap:LONG_FILENAME:1
Recv:3:57:02.509: Cap:LFN_WRITE:0
Recv:3:57:02.512: Cap:CUSTOM_FIRMWARE_UPLOAD:0
Recv:3:57:02.514: Cap:EXTENDED_M20:1
Recv:3:57:02.516: Cap:THERMAL_PROTECTION:1
Recv:3:57:02.518: Cap:MOTION_MODES:0
Recv:3:57:02.519: Cap:ARCS:0
Recv:3:57:02.521: Cap:BABYSTEPPING:1
Recv:3:57:02.523: Cap:EP_BABYSTEP:0
Recv:3:57:02.525: Cap:CHAMBER_TEMPERATURE:0
Recv:3:57:02.529: Cap:COOLER_TEMPERATURE:0
Recv:3:57:02.529: Cap:MEATPACK:0
Recv:3:57:02.532: Cap:CONFIG_EXPORT:0
Recv:3:57:02.532: ok (N4)
Send:3:57:02.532: N5 M220 S100 ; Speed multiplier 100%
Recv:3:57:02.545: ok (N5)
Send:3:57:02.545: N6 M221 S100 ; Flow multiplier 100%
Recv:3:57:02.565: ok (N6)
Send:3:57:02.565: N7 G92 E0
Recv:3:57:02.571: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv:3:57:02.571: ok (N7)
Send:3:57:02.571: N8 G90
Recv:3:57:02.573: ok (N8)
Send:3:57:02.573: N9 M82
Recv:3:57:02.574: ok (N9)
Send:3:57:02.574: N10 G21 ; Use mm as unit
Recv:3:57:02.576: ok (N10)
Send:3:57:02.576: N11 M114
Exec:3:57:02.576: @getIP
Recv:3:57:03.577: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv:3:57:03.577: ok (N11)
Send:3:57:03.584: N13 M114
Exec:3:57:03.584: @startCodeProcessed
Send:3:57:03.584: N14 M155 S1
Send:3:57:03.584: M117 192.168.1.52:3344
Recv:3:57:03.590: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv:3:57:03.590: ok (N13)
Recv:3:57:03.590: ok (N14)
Recv:3:57:05.764: echo:Unknown command: "[ 17.598172] rc.local[1354]: My IP address is 192.168.1.52"
Mesg:3:57:05.764: Received extra ok - ignored
Recv:3:57:05.764: ok
Mesg:3:57:06.794: Connection closed by os.
Mesg:3:57:07.936: Dtr: false Rts: false
Mesg:3:57:07.957: Connection started
Mesg:3:57:07.957: Printer reset requested - emergency:false
Mesg:3:57:08.013: Dtr: true Rts: true
Mesg:3:57:08.033: Dtr: false Rts: false
Recv:3:57:08.040: Response while unconnected:echo:Unknown command: "echo:U"echo:Unknown command: "repelogi"
Recv:3:57:08.040: echo:Unknown command: "echo:U"echo:Unknown command: "repelogi"
Recv:3:57:08.040: Connection verified by:ok
Mesg:3:57:08.040: Received extra ok - ignored
Recv:3:57:08.040: ok
Send:3:57:08.040: N1 M110
Recv:3:57:08.042: Line: 1
Recv:3:57:08.042: ok (N1)
Send:3:57:08.055: N4 M115 ; Get firmware capabilities and info
Recv:3:57:08.078: FIRMWARE_NAME:Marlin 2.1.3-beta3 (Jul 3 2025 14:43:58) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 Pro KINEMATICS:Cartesian EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv:3:57:08.080: Cap:SERIAL_XON_XOFF:0
Recv:3:57:08.083: Cap:BINARY_FILE_TRANSFER:0
Recv:3:57:08.084: Cap:EEPROM:1
Recv:3:57:08.085: Cap:VOLUMETRIC:1
Recv:3:57:08.087: Cap:AUTOREPORT_POS:0
Recv:3:57:08.091: Cap:AUTOREPORT_TEMP:1
Recv:3:57:08.091: Cap:PROGRESS:0
Recv:3:57:08.093: Cap:PRINT_JOB:1
Recv:3:57:08.094: Cap:AUTOLEVEL:0
Recv:3:57:08.095: Cap:RUNOUT:0
Recv:3:57:08.097: Cap:Z_PROBE:0
Recv:3:57:08.098: Cap:LEVELING_DATA:1
Recv:3:57:08.100: Cap:BUILD_PERCENT:1
Recv:3:57:08.102: Cap:SOFTWARE_POWER:0
Recv:3:57:08.105: Cap:TOGGLE_LIGHTS:0
Recv:3:57:08.107: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv:3:57:08.109: Cap:EMERGENCY_PARSER:1
Recv:3:57:08.112: Cap:HOST_ACTION_COMMANDS:0
Recv:3:57:08.114: Cap:PROMPT_SUPPORT:0
Recv:3:57:08.115: Cap:SDCARD:1
Recv:3:57:08.117: Cap:MULTI_VOLUME:0
Recv:3:57:08.118: Cap:REPEAT:0
Recv:3:57:08.120: Cap:SD_WRITE:0
Recv:3:57:08.122: Cap:AUTOREPORT_SD_STATUS:0
Recv:3:57:08.124: Cap:LONG_FILENAME:1
Recv:3:57:08.125: Cap:LFN_WRITE:0
Recv:3:57:08.128: Cap:CUSTOM_FIRMWARE_UPLOAD:0
Recv:3:57:08.130: Cap:EXTENDED_M20:1
Recv:3:57:08.137: Cap:THERMAL_PROTECTION:1
Recv:3:57:08.138: Cap:MOTION_MODES:0
Recv:3:57:08.138: Cap:ARCS:0
Recv:3:57:08.138: Cap:BABYSTEPPING:1
Recv:3:57:08.139: Cap:EP_BABYSTEP:0
Recv:3:57:08.141: Cap:CHAMBER_TEMPERATURE:0
Recv:3:57:08.144: Cap:COOLER_TEMPERATURE:0
Recv:3:57:08.145: Cap:MEATPACK:0
Recv:3:57:08.147: Cap:CONFIG_EXPORT:0
Recv:3:57:08.147: ok (N4)
Send:3:57:08.147: N5 M220 S100 ; Speed multiplier 100%
Recv:3:57:08.149: ok (N5)
Send:3:57:08.149: N6 M221 S100 ; Flow multiplier 100%
Recv:3:57:08.152: ok (N6)
Send:3:57:08.152: N7 G92 E0
Recv:3:57:08.159: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv:3:57:08.159: ok (N7)
Send:3:57:08.159: N8 G90
Recv:3:57:08.162: ok (N8)
Send:3:57:08.162: N9 M82
Recv:3:57:08.164: ok (N9)
Send:3:57:08.164: N10 G21 ; Use mm as unit
Recv:3:57:08.166: ok (N10)
Send:3:57:08.166: N11 M114
Exec:3:57:08.167: @getIP
Recv:3:57:08.172: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv:3:57:08.172: ok (N11)
Send:3:57:08.173: N12 M114
Exec:3:57:08.173: @startCodeProcessed
Send:3:57:08.173: N13 M155 S1
Send:3:57:08.173: M117 192.168.1.52:3344
Recv:3:57:08.178: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv:3:57:08.178: ok (N12)
Recv:3:57:08.179: ok (N13)
Mesg:3:57:37.292: Connection closed by os.
