Linux Mint 17.3 Rosa KDE
Repetier-Host V1.6.1
Firmware 0.92.8
Sorry in advance if it came up already. I didn't find it.
Many trials, no cigar.
For each of these trials I uploaded everything anew to the eeprom (with diff. EEPROM_MODE number).
With:
NUM_EXTRUDER 3 and MIXING_EXTRUDER 1 no heating, all extruders turned at the same time, whichever extruder I chose in the right hand corner.
NUM_EXTRUDER 3 and MIXING_EXTRUDER 0 I got only heating when I clicked on the Extruder 3 (in the middle). I got response in the Output Extruder-graphics with each of the chosen Extruders (in the corner), only with Extruder 3 I got heat also.
Only the extruder I chose in the corner turned.
NUM_EXTRUDER 1 and MIXING_EXTRUDER 0 I got heat and movement as expected, but that isn't what I hoped with the diamond. ;-)
Which proofs, in my humble opinion that it is a software question. Nevertheless, when nothing helped I replaced the electronics: no difference.
I suppose that the turning extruders, all together, go with the beautiful mixing options, and that they will be weighted accordingly when the slicing is done.
But now I would be happy with the different filaments, for instance PLA and PVA, together, but not at the same time. I hope that Slic3r does fill in the 100%-0% weights when appropriate but as long I don't get nozzle-heating... ;-(
I use a CNC shield for the third extruder, so obviously I tried things without that PCB, and NUM_EXTRUDER 2: no improvement.
The relevant portions of pins.h:
#if MOTHERBOARD == 33
#define KNOWN_BOARD 1
#define RAMPS_V_1_3
#ifdef RAMPS_V_1_3
#define ORIG_X_STEP_PIN 54
#define ORIG_X_DIR_PIN 55
#define ORIG_X_ENABLE_PIN 38
#define ORIG_X_MIN_PIN 3
#define ORIG_X_MAX_PIN 2
#define ORIG_Y_STEP_PIN 60
#define ORIG_Y_DIR_PIN 61
#define ORIG_Y_ENABLE_PIN 56
#define ORIG_Y_MIN_PIN 14
#define ORIG_Y_MAX_PIN 15
#define ORIG_Z_STEP_PIN 46
#define ORIG_Z_DIR_PIN 48
#define ORIG_Z_ENABLE_PIN 62
#define ORIG_Z_MIN_PIN 18
#define ORIG_Z_MAX_PIN 19
#define ORIG_E0_STEP_PIN 26
#define ORIG_E0_DIR_PIN 28
#define ORIG_E0_ENABLE_PIN 24
#define ORIG_E1_STEP_PIN 36
#define ORIG_E1_DIR_PIN 34
#define ORIG_E1_ENABLE_PIN 30
#define ORIG_E2_STEP_PIN 64
#define ORIG_E2_DIR_PIN 59
#define ORIG_E2_ENABLE_PIN 44
#define SDPOWER -1
#define SDSS 53
#define ORIG_SDCARDDETECT 49
#define LED_PIN 13
#define ORIG_FAN_PIN 9
#define ORIG_PS_ON_PIN 12
#define HEATER_0_PIN 10
#define HEATER_1_PIN 8
#define HEATER_2_PIN 9
// ANALOG NUMBERING
#define TEMP_0_PIN 13
#define TEMP_1_PIN 14
#define TEMP_2_PIN 15
#define E0_PINS ORIG_E0_STEP_PIN,ORIG_E0_DIR_PIN,ORIG_E0_ENABLE_PIN,
#define E1_PINS ORIG_E1_STEP_PIN,ORIG_E1_DIR_PIN,ORIG_E1_ENABLE_PIN,
#define E2_PINS ORIG_E2_STEP_PIN,ORIG_E2_DIR_PIN,ORIG_E2_ENABLE_PIN,
I hesitate to print also the complete Configuration.h file, but could imagine it is necessary, so please let me know.
Thank you all for any suggestions.
And thank you, people at Repetier, for all that beatiful stuff, which already helped me a lot and without which I would be completely lost.
