<font face="Arial, Verdana">Download latest firmware from site wizard with this config inside</font>
<font face="Arial, Verdana">http://pastebin.com/YsZysqqz</span></font><br/></div><div><font face="Arial, Verdana">
</font>
If I press control buttons in repetier-host, m<font face="Arial, Verdana">y extruder motor just whistles and dont turn . Cold extrusion allowed with M302. G10 command disabled in firmware.</font>
<font face="Arial, Verdana">Print from Simplify3D works, except retraction has only z-lift of head(as I setup) and no filament reverse movement(I set 4mm).</font>
</font>
<font face="Arial, Verdana">If I only change </font>#define DRIVE_SYSTEM 3 to 0 in config, extruder turn from repetier-host buttons commands as expected.
Also works in Marlin.
</font>
<font face="Arial, Verdana">Why extruder work during print and whistle from repetier-host buttons?</font>
</font>
<font face="Arial, Verdana">Here coomands from Host log</font>
00:58:34.174 : N347 G1 E1 F12041
00:58:38.355 : N351 G1 E-1 F1800*57
Try master branch from github with default config - get the same results. Set DRIVE_SYSTEM 3 broke my extruder motor motion.
</font>
