<font face="Arial, Verdana">Ok, this is strange...</font>
This is my g-code:
<font face="Arial, Verdana">;Basic settings: Layer height: 0.2 Walls: 0.8 Fill: 20</font>
<font face="Arial, Verdana">;Print time: 6 minutes</font>
<font face="Arial, Verdana">;Filament used: 0.52m 1.0g</font>
<font face="Arial, Verdana">;Filament cost: None</font>
<font face="Arial, Verdana">G21 ;metric values</font>
<font face="Arial, Verdana">G90 ;absolute positioning</font>
<font face="Arial, Verdana">M82 ;set extruder to absolute mode</font>
<font face="Arial, Verdana">M107 ;start with the fan off</font>
<font face="Arial, Verdana">G28 X0 Y0 ;move X/Y to min endstops</font>
<font face="Arial, Verdana">G28 Z0 ;move Z to min endstops</font>
<font face="Arial, Verdana">G1 Z5.0 F7800 ;move the platform down 5mm</font>
<font face="Arial, Verdana">M190 S70 ;Uncomment to add your own bed temperature line</font>
<font face="Arial, Verdana">M109 S190 ;Uncomment to add your own temperature line</font>
<font face="Arial, Verdana">G92 E0 ;zero the extruded length</font>
<font face="Arial, Verdana">G1 F200 E3 ;extrude 3mm of feed stock</font>
<font face="Arial, Verdana">G92 E0 ;zero the extruded length again</font>
<font face="Arial, Verdana">G1 F7800</font>
<font face="Arial, Verdana">;Put printing message on LCD screen</font>
<font face="Arial, Verdana">M117 Printing...</font>
</font>
<font face="Arial, Verdana">;Layer count: 13</font>
<font face="Arial, Verdana">;LAYER:0</font>
<font face="Arial, Verdana">M107</font>
<font face="Arial, Verdana">G0 F7800 X96.009 Y72.749 Z0.300</font>
<font face="Arial, Verdana">;TYPE:SKIRT</font>
<font face="Arial, Verdana">G1 F1800 X126.239 Y73.955 E1.50938</font>
</font>
<font face="Arial, Verdana">So in this case, the printer does not lower to .3 as it should, and it also goes faster than what I told it to go (50 mm/s) for the first several G1 commands. If I add an @pause either on top of under the TYPE:SKIRT line, it works :) the printer goes down to z=.3 and the speed is at 50 mm/s. I don't know why this works, but it works.</font>
