WOOHOO! Major progress report!
That Gcode did the trick and the extruder is turning
I set the end stops and the temps on the bed and the extruder to what the software says should be correct temps however, when I start the calibration test print and the filment is don't really coming out very well I also noticed that the hotend itself wants to swing back and forth in the extruder. I suspect that the movement of the hot end has to do with it melting the extruder, I think I have a fix for this already but suggestions would be great. Its a Wades just in case you want that info.
As far as the filment, Im not sure what to do here as the temp on the hotend is already set at 240 and the it does print some material out but its really slow, should I set the feed rate lower or the flow rate higher?
help help help, I am really excited to start printing on this bad boy!
