I am having some weird behaviour on CURA with 1.6.0. The retraction enable is checked but the output gcode will not output any retractions at all. I reinstalled the software and used the default profile and it started outputting retractions again.
After one day the retractions are missing again from the gcode.
Retraction distance is 1.0mm
Speed is 40mm/s
Minimum travel is 1.5mm
And Minimum Extrusion before retract is 0.02
The only retraction it will do is during the move on the skirt around the part, after that it is missing on all layers and moves.
Any insight would be nice!
