moved from .92.5 to .92.8
imported the config file from previous build.
only change was to extruder acceleration.
New build seems to crash regularly, while sending the first few commands or even just attempting to connect.
Get rows of black boxes on display.
Guessing those are 0xFF or 0x00 being written to display RAM incorrectly.
Strangely I did get a few full layers once or twice.
Sometimes failure does not seem to reach the display and seems like a simple usb disconnect, however it requires a reset to clear it
and reconnect so I suspect it is the same issue just that it doesn't reach the display.
Tried 3 different times with three fresh downloads and builds with the same results.
Tried using both Repetier Host and my Astrobox with similar results,
reverting to .92.5 solved cleared the problem.
I am wondering if there is any revision document that shows changes from one version to the next if so I can't find it.
