Thanks for the explanation. Your dedicated support is much appreciated!!!
Have been struggling since downloading repetier firmware 12-27-2015 (just saw tonight that you released an update about firmware on 1-3-2016 regarding bed correction method).
In short I believe my problem configuring skeinforge is not skeinforge but related to z axis...I cross referenced using repetier firmware, matter control host, and matter slice problem repeats. I move to X90 Y90 and home Z, set Z probe offset touch off on a piece of paper and good to go, when I home at bed before start repeats and is just above of the surface of the bed. But the problem is that when it starts to print, first layer thickness should be .15mm and by canceling the print and using feeler gages the nozzle is 1.01mm off of the bed, taking into consideration it is within 5mm X and Y of part center aka Z delta should be relatively small. So in short even when I got the first layer set the layer height of .2mm was larger than it should be. I have checked Z calibration with steps per mm and that is spot on, had used a value of approx. 3900 when 4000 should be nominal. Turns out plugging in 4000 and moving Z up 100mm I am within 1mm (measured with a ruler), so 1 mm over 100 does not equate to 1mm over .2mm layer. Not trying to over explain, was trying to keep this brief, I know you have a lot to read.
Will the bed correction method take care of this? I will find out in about 18hrs when I get to try this again, but wanted to get your thoughts. Any other parameters that I should look at/modify?
Thanks again for the help!
