Repetier
There are 2 max pwm values. If you really see 100% in host temperature then your heater is too weak. Fan cools more then you can heat. Normally this is not the case for full metal hotends that need extra cooling and it is the pwm. Also check eeprom values.
Privacy Policy  |  About Us
