Bob_le_herisson bonsoir,faut-il attendre la fin de la période d'essai pour entrer le N° de licencedo you have to wait until the end of the trial period to enter the license number
Bob_le_herisson ça a bien voulu maintenant tout va bien c'était un caprice momentané de Repetier server
Repetier I'm not sure here. In any case there is problem/difference when you activate it after the trial. All functionality during trial is identical to pro version and you will not loose any data. Maximum what happen is if you have more then 2 printers it will deactivate some until license is entered.Anyhow if you see in register window the license key and can enter your key it should work.
