hi. I just dont understand the instructions on how to get this working. I have a custom CoreXY and there very little information regarding this for this type of printer configuration.
I have manually leveled the nozzle against the bed by just being able to slide a piece of paper.
At that point Prove is triggered ( also min hardware endstop is connected but not triggered since is a little higher )
Then i home all and issue command for probing. Prove high in firmware is set to 1mm
is the above corect? After this now what?
Whats that about not using min endstop and using max endstop? its a little impractical in a CoreXY.
CAn anyone point me to the correct proces?
