Latest 0.92.6 has a START_GCODE option where you could put the command in, but be aware that this only works if controller only works with full power. If it already enables with usb power you get a heater decoupled.
Also be aware that this is dangerous since reconnect would also turn on heaters so you often have heaters on even not wanted.
So, yes possible if you know what you are doing.
