There is surely something wrong. First honeywell produces more then 1 thermistor, so make sure your setting matches the one you have.
You also use the term thermocouple, which is something different then thermistor. You can not put a thermistor in a thermocouple pin and not a thermistor into a thermocouple pin. Well you can, but the result will be not what you expect.
So check what you really have and where you connected it.
