Here is my log file during the error.
Send:22:40:23.105: N988589 G1 X30.202 Y110.121 E125.42472
Recv:22:40:23.105: ok (N988589)
Send:22:40:23.105: N988590 G1 X32.338 Y106.801 E125.63221
Recv:22:40:23.106: ok (N988590)
Send:22:40:23.106: N988591 G1 X34.555 Y103.536 E125.83963
Recv:22:40:23.106: ok (N988591)
Send:22:40:23.106: N988592 G1 X36.853 Y100.327 E126.04707
Recv:22:40:23.106: ok (N988592)
Send:22:40:23.106: N988593 G1 X39.23 Y97.176 E126.25452
Recv:22:40:23.403: ok (N988593)
Send:22:40:23.403: N988594 G1 X41.684 Y94.085 E126.46195
Recv:22:40:23.404: ok (N988594)
Send:22:40:23.404: N988595 G1 X44.214 Y91.055 E126.66941
Recv:22:40:23.404: ok (N988595)
Send:22:40:23.404: N988596 G1 X46.818 Y88.089 E126.87685
Recv:22:40:23.404: ok (N988596)
Send:22:40:23.404: N988597 G1 X49.495 Y85.189 E127.08428
Recv:22:40:23.405: ok (N988597)
Send:22:40:23.405: N988598 G1 X52.244 Y82.357 E127.29171
Recv:22:40:43.570: // Klipper state: Shutdown
Recv:22:40:43.571: ok (N988598)
Send:22:40:43.572: Slow command added:M400 ; Wait for current moves to finish, clearing the buffer
Send:22:40:43.572: N988599 M400 ; Wait for current moves to finish, clearing the buffer
Recv:22:40:43.576: // Lost communication with MCU 'mcu'
Recv:22:40:43.576: // Once the underlying issue is corrected, use the
Recv:22:40:43.576: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.580: // config, and restart the host software.
Recv:22:40:43.580: // Printer is shutdown
Recv:22:40:43.580: !! Lost communication with MCU 'mcu'
Recv:22:40:43.580: ok (N988599)
Send:22:40:43.580: N988600 M104 T0 S0 ; Disable extruder
Recv:22:40:43.583: // Lost communication with MCU 'mcu'
Recv:22:40:43.583: // Once the underlying issue is corrected, use the
Recv:22:40:43.583: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.583: // config, and restart the host software.
Recv:22:40:43.583: // Printer is shutdown
Recv:22:40:43.583: !! Lost communication with MCU 'mcu'
Recv:22:40:43.584: ok (N988600)
Send:22:40:43.584: N988601 M140 S0 ; Disable bed
Recv:22:40:43.584: // Lost communication with MCU 'mcu'
Recv:22:40:43.584: // Once the underlying issue is corrected, use the
Recv:22:40:43.585: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.585: // config, and restart the host software.
Recv:22:40:43.585: // Printer is shutdown
Recv:22:40:43.585: !! Lost communication with MCU 'mcu'
Recv:22:40:43.585: ok (N988601)
Send:22:40:43.585: N988602 G91 ;Relative mode
Recv:22:40:43.586: // Lost communication with MCU 'mcu'
Recv:22:40:43.586: // Once the underlying issue is corrected, use the
Recv:22:40:43.586: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.586: // config, and restart the host software.
Recv:22:40:43.586: // Printer is shutdown
Recv:22:40:43.586: !! Lost communication with MCU 'mcu'
Recv:22:40:43.586: ok (N988602)
Send:22:40:43.586: N988603 G1 Z10 F1000 ;Move Bed down 10 mm
Recv:22:40:43.587: // Lost communication with MCU 'mcu'
Recv:22:40:43.587: // Once the underlying issue is corrected, use the
Recv:22:40:43.588: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.588: // config, and restart the host software.
Recv:22:40:43.588: // Printer is shutdown
Recv:22:40:43.588: !! Lost communication with MCU 'mcu'
Recv:22:40:43.588: ok (N988603)
Send:22:40:43.588: N988604 G90 ;Absolute Mode
Recv:22:40:43.589: // Lost communication with MCU 'mcu'
Recv:22:40:43.589: // Once the underlying issue is corrected, use the
Recv:22:40:43.589: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.589: // config, and restart the host software.
Recv:22:40:43.589: // Printer is shutdown
Recv:22:40:43.589: !! Lost communication with MCU 'mcu'
Recv:22:40:43.589: ok (N988604)
Send:22:40:43.590: N988605 G1 X0 Y0 F4000
Recv:22:40:43.590: // Lost communication with MCU 'mcu'
Recv:22:40:43.591: // Once the underlying issue is corrected, use the
Recv:22:40:43.591: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.591: // config, and restart the host software.
Recv:22:40:43.591: // Printer is shutdown
Recv:22:40:43.591: !! Lost communication with MCU 'mcu'
Recv:22:40:43.592: ok (N988605)
Send:22:40:43.592: N988606 M84 ; Disable motor
Recv:22:40:43.592: // Lost communication with MCU 'mcu'
Recv:22:40:43.592: // Once the underlying issue is corrected, use the
Recv:22:40:43.593: // "FIRMWARE_RESTART" command to reset the firmware, reload the
Recv:22:40:43.593: // config, and restart the host software.
Recv:22:40:43.593: // Printer is shutdown
Recv:22:40:43.593: !! Lost communication with MCU 'mcu'
Recv:22:40:43.593: ok (N988606)
Exec:22:40:43.593: @stopLog
