don't work
i thing there are a bug in firmware with mixing
if define that in configuration.h :
#define NUM_EXTRUDER 3
#define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT1_HEATER_PIN HEATER_0_PIN
#define EXT2_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT2_HEATER_PIN HEATER_0_PIN
the fan work, i see a same real temperature for 3 extruder but i loss the heating ( the same low blinking )
if define that :
#define EXT2_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT2_HEATER_PIN HEATER_2_PIN
and modifie my pins.h
#define HEATER_0_PIN 10
#define HEATER_1_PIN 8
#define HEATER_2_PIN 10 //9
#define TEMP_0_PIN 13 // ANALOG NUMBERING
#define TEMP_1_PIN 14 // ANALOG NUMBERING
#define TEMP_2_PIN 13 //15
it the same low blinking for heat, and i see a real temperature on 3 extruder
where there are other setup ?
thanks
