Hello, Still got problem, I followed the instruction that are on RH site:
Verify z-probe
Before you risk any damage, you should test, if you have configured the z-probe correctly. Run a
G31
to
check the signal of the z-probe. It should be low/off. Now trigger it
by hand and send the command again. Make sure the signal is now
inverted.
When I run G31 command I get Z-probe state:H, when I trigger my switch and send the command again i get the same result-> Z-probe state:H
Does this mean that I wired microswitch wrong to the board or something else? (please see the picture of the ramps, where I wired my switch)
thanks for reply
