Please check if the clock is set correctly or server can not access secure websites. Clock normally adjust after a few minutes with internet connection, except when internet is blocked on port 53, 80 or 443.
Easiest solution to rotate is the rotate function in our setup tool. When you use this pleas eundo your rotation solution first so touch and rotation match, then follow the instructions in the correct order - first select screen rotation and only then include the touch screen rotation and then apply and confirm. Order matters.
