Not sure should I post this in Feature request or Bug report.
It would be great if I could set some model to print only on second or third extender.
I have low temperature extruder (extruder 1) and high temperature extruder (extuder 2).
Sometimes I need to print only on 2nd one.
With Repetier is sounds simple, just change extruder for model, slice and print.
But when model is sliced, it use extruder 1 even when extruder is changed in model settings.
Usually I manually change G-code to switch print to second extruder adding T1 Gcode after initial movement to Z15, and replacing heater setting M104 and M109 to T1. After that I can send to printer and everything prints fine.
It would be great if you can set after slicing this extruder change, so no manual editing would be required.
