uno online said:
Want to use a different controller card. Now I use a 8 bit card . Mks gen l... (ramps clone) want to try 32 bit card. Must work with Repetier firmware. Any suggestions ?
Very satisfied with the Repetier FW
If you are looking for a 32-bit controller card that is compatible with Repetier firmware, you can try the RADDS board. The RADDS board is a good choice for Repetier firmware and is compatible with the current stable branch V1.
The Alligator Board rev1, Alligator Board rev2, Alligator Board rev3, DAM&DICE DUE (based on RAMPS), DUE3DOM, DUE3DOM MINI, Felix Printers for arm, and STACKER 3D Superboard are also compatible with Repetier firmware.
