xobtor I have built a cnc which uses marlin When I use the emergency stop 3 out of 5 steppers cut off Also when job finishes I’m a relative newby so please be gentle Any suggestions would be helpful
Repetier What exactly is the problem? That 2 stay enabled or the 3 being turned off? Seehttps://marlinfw.org/docs/gcode/M018.html<br/><br/>These commands disable motors so I assume they are at the end of your g-code.
