Hi There
I've been try to upgrade my Ultratronics board to V2 firmware mostly following the procedure used by "lmcbmai" a few years ago. I've had some success. The Y axis homes and works , the extruder works, the heaters and thermistors work but I can't get the X and Z axis to move at all. If I try to home the X axis it enables and gives a slight "buzz" but that's all. I have 2 Z motors and they do nothing. I use external stepper drivers. I can't think of what else to try.
Here is how I have set them up
// X Motor
IO_OUTPUT(IOX1Step, ORIG_X_STEP_PIN)
IO_OUTPUT(IOX1Dir, ORIG_X_DIR_PIN)
IO_OUTPUT_INVERTED(IOX1Enable, ORIG_X_ENABLE_PIN)
// Y Motor
IO_OUTPUT(IOY1Step, ORIG_Y_STEP_PIN)
IO_OUTPUT_INVERTED(IOY1Dir, ORIG_Y_DIR_PIN)
IO_OUTPUT_INVERTED(IOY1Enable, ORIG_Y_ENABLE_PIN)
/// Z Motor
IO_OUTPUT(IOZ1Step, ORIG_Z_STEP_PIN)
IO_OUTPUT_INVERTED(IOZ1Dir, ORIG_Z_DIR_PIN)
IO_OUTPUT(IOZ1Enable, ORIG_Z_ENABLE_PIN)
// Z Motor 1
// Z Motor 2
IO_OUTPUT(IOZ2Step, ORIG_E2_STEP_PIN)
IO_OUTPUT_INVERTED(IOZ2Dir, ORIG_E2_DIR_PIN)
IO_OUTPUT(IOZ2Enable, ORIG_E2_ENABLE_PIN)
// E0 Motor
IO_OUTPUT(IOE1Step, ORIG_E0_STEP_PIN)
IO_OUTPUT_INVERTED(IOE1Dir, ORIG_E0_DIR_PIN)
IO_OUTPUT_INVERTED(IOE1Enable, ORIG_E0_ENABLE_PIN)
// Define all stepper motors used
STEPPER_SIMPLE(XMotor, IOX1Step, IOX1Dir, IOX1Enable, endstopXMin, endstopNone)
STEPPER_SIMPLE(YMotor, IOY1Step, IOY1Dir, IOY1Enable, endstopNone, endstopXMax)
STEPPER_SIMPLE(Z1Motor, IOZ1Step, IOZ1Dir, IOZ1Enable, endstopZMin, endstopNone)
STEPPER_SIMPLE(Z2Motor, IOE2Step, IOE2Dir, IOE2Enable, endstopZMin, endstopNone)
STEPPER_MIRROR2(ZMotor, Z1Motor, Z2Motor, endstopNone, endstopNone);
STEPPER_SIMPLE(E1Motor, IOE1Step, IOE1Dir, IOE1Enable, endstopNone, endstopNone)
//STEPPER_OBSERVEABLE(E1Motor, E1MotorBase)
//STEPPER_SIMPLE(E2MotorBase, IOE2Step, IOE2Dir, IOE2Enable, endstopNone, endstopNone)
//STEPPER_OBSERVEABLE(E2Motor, E2MotorBase)
//STEPPER_SIMPLE(AL1Motor, IOAL1Step, IOAL1Dir, IOAL1Enable, endstopNone, endstopNone)
//STEPPER_SIMPLE(AL2Motor, IOAL2Step, IOAL2Dir, IOAL2Enable, endstopNone, endstopNone)
// Define your endstops inputs
IO_INPUT(IOEndstopXMin, ORIG_X_MIN_PIN)
// IO_INPUT_INVERTED(IOEndstopXMin, ORIG_X_MIN_PIN)
IO_INPUT(IOEndstopYMax, ORIG_Y_MAX_PIN)
IO_INPUT_PULLUP(IOEndstopZMin, ORIG_Z_MIN_PIN)
/ Define our endstops solutions
// You need to define all min and max endstops for all
// axes except E even if you have none!
ENDSTOP_SWITCH_HW(endstopXMin, IOEndstopXMin, X_AXIS, false)
ENDSTOP_NONE(endstopXMax)
ENDSTOP_NONE(endstopYMin)
ENDSTOP_SWITCH_HW(endstopYMax, IOEndstopYMax, Y_AXIS, true)
ENDSTOP_SWITCH_HW(endstopZMin, IOEndstopZMin, Z_AXIS, false)
ENDSTOP_NONE(endstopZMax)
Thank you
