Hello all
I upgraded my XYZ da vinci 2 duo to repetier host after about 6 months of using it with the stock firmware.
The printer was printing OK before but I wanted the repetier features like using PLA or not having to reset cartridges.
Now, after leveling the table when I try to print with ABS or PLA, the objects don't adhere to the table.
Temp is correct
I am using repetier host for windows version 1.5.4 with slic3r 1.2.9
I saw a youtube video where I can configure slic3r to use a Z offset to force the extruder to be closer to the table but on my computer that option is gone.
It was supposed to be under the printer settings tab in slic3r but it is not there
Then I installed repetier host for mac but it seems to be an older version 0.56 without many features like manual control
And I am using repetier server with a raspberry pi 2
PLEASE HELP
I just need to lower the extruder because now it it starting in mid air and that is the reason it is not adhering to the bed.
THANK YOU
Rod Magnus
