Right now you can go into a file, show gcode and edit the parameters.
In a project that has quite a few files would it be possible to add a bulk change option for bed and material temp and/or material type?
I'll slice a project in one material and sometimes later on want to print the same project in a different material. Rather than reslicing all of the files again, I can go in and change the bed/nozzle temps in the files of a project. Of course I can change the temp at print time, buut, sometimes I forget. ;-)
Being able to bulk change a bunch of files at once, or being able to copy the whole project with the option to change material and temps for that project at copy time. And of course the project rename to differentiate the two.
