I'm still working on updating my Firmware, now mostly running but run in a strange problem. When I upload the firmware, the heated bed works normal, but as soon as I connect with Repetier Server to the printer, the display of the heated bed temp on the display changes to zero, and I can't turn the heat on anymore. Even when I disconnect the server and reset the printer there is no heated bed. When I upload the firmware again the heated bed is back. what can this be?
This is my configuration.h
Thanks,
along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.<br/><br/>*/<br/><br/>#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/**************** READ FIRST *********************
This file is optimized for version 1.0.4dev
generator: http://www.repetier.com/firmware/dev/<br/><br/> If you are in doubt which named functions use which pins on your board, please check the
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 80
#include "pins.h"
#define HOST_RESCUE 1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#undef X_MIN_PIN
#define X_MIN_PIN -1
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef Y_STEP_PIN
#define Y_STEP_PIN ORIG_E2_STEP_PIN
#undef Y_DIR_PIN
#define Y_DIR_PIN ORIG_E2_DIR_PIN
#undef Y_ENABLE_PIN
#define Y_ENABLE_PIN ORIG_E2_ENABLE_PIN
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define ZAXIS_STEPS_PER_MM 100
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_START_COMMANDS "M25"
#define PAUSE_END_COMMANDS "M24"
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 187
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_REHOME 2
#define FILAMENTCHANGE_LONGRETRACT 250
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 1
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 310
#define MAX_DEFECT_TEMPERATURE 325
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 10
#define ENDSTOP_Y_BACK_ON_HOME 10
#define ENDSTOP_Z_BACK_ON_HOME 10
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 1
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 1
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 448
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 355 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 150
#define ROD_RADIUS 184.96
#define PRINTER_RADIUS 184.96
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 250
#define MAX_FEEDRATE_Y 250
#define MAX_FEEDRATE_Z 250
#define HOMING_FEEDRATE_X 50
#define HOMING_FEEDRATE_Y 50
#define HOMING_FEEDRATE_Z 50
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define STARTUP_GCODE ";Home G28 G1 X0 Y-100 Z030 F5000 ;Prime the extruder G92 E0 G1 F200 E30 G92 E0"
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 7
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 1.14
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 100
#define Z_PROBE_X2 60
#define Z_PROBE_Y2 -90
#define Z_PROBE_X3 -60
#define Z_PROBE_Y3 -90
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#endif
#define SD_EXTENDED_DIR 1 / Show extended directory including file length. Don't use this with Pronterface!
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 1
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define LANGUAGE_RU_ACTIVE 0
#define UI_PRINTER_NAME "LoiLand 3D Printer"
#define UI_PRINTER_COMPANY "LoiLand Design Comp"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN ORIG_FAN2_PIN
#define UI_SET_MAX_HEATED_BED_TEMP 130
#define UI_SET_MIN_EXTRUDER_TEMP 150
#define UI_SET_MAX_EXTRUDER_TEMP 315
#define NUM_MOTOR_DRIVERS 0
#endif
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 100,
"yStepsPerMM": 100,
"zStepsPerMM": 100,
"xInvert": "1",
"x2Invert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": "1",
"y2Invert": 0,
"yInvertEnable": 0,
"zInvert": "1",
"z2Invert": 0,
"z3Invert": 0,
"z4Invert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 1,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 1,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "1",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 187,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 190
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 0,
"yMinEndstop": 0,
"zMinEndstop": 1,
"xMaxEndstop": 2,
"yMaxEndstop": 2,
"zMaxEndstop": 2,
"x2MinEndstop": 0,
"y2MinEndstop": 0,
"x2MaxEndstop": 0,
"y2MaxEndstop": 0,
"motherboard": 80,
"driveSystem": 3,
"xMaxSpeed": 250,
"xHomingSpeed": 50,
"xTravelAcceleration": 1000,
"xPrintAcceleration": 1000,
"yMaxSpeed": 250,
"yHomingSpeed": 50,
"yTravelAcceleration": 1000,
"yPrintAcceleration": 1000,
"zMaxSpeed": 250,
"zHomingSpeed": 50,
"zTravelAcceleration": 1000,
"zPrintAcceleration": 1000,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 448,
"alwaysCheckEndstops": "1",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": 1,
"xEndstopBack": 10,
"yEndstopBack": 10,
"zEndstopBack": 10,
"deltaDiagonalRod": 355,
"deltaHorizontalRadius": 184.96,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 20,
"stepperHighDelay": 0,
"directionDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"mirrorZ4": "0",
"mirrorZ4Motor": {
"name": "Extruder 3",
"step": "ORIG_E3_STEP_PIN",
"dir": "ORIG_E3_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "1",
"hasHeatedBed": "1",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"featureController": 2,
"uiPrinterName": "LoiLand 3D Printer",
"uiPrinterCompany": "LoiLand Design Comp",
"uiPagesDuration": 4000,
"uiHeadline": "",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 130,
"uiMinEtxruderTemp": 150,
"uiMaxExtruderTemp": 315,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 1,
"bedPreheat": 55,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": "ORIG_FAN2_PIN",
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 310,
"minDefectTemp": -10,
"maxDefectTemp": 325,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 1,
"scalePidToMax": "1",
"zProbeBedDistance": 10,
"zProbeDisableHeaters": "0",
"zProbePullup": "0",
"zProbeOnHigh": "0",
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 7,
"zProbeXYSpeed": 150,
"zProbeHeight": 1.14,
"zProbeStartScript": "",
"zProbeFinishedScript": "",
"featureAutolevel": "1",
"zProbeX1": 0,
"zProbeY1": 100,
"zProbeX2": 60,
"zProbeY2": -90,
"zProbeX3": -60,
"zProbeY3": -90,
"zProbeSwitchingDistance": 1,
"zProbeRepetitions": 2,
"zProbeMedian": "0",
"zProbeEveryPoint": "",
"sdSupport": "0",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": -1,
"yMinPin": -1,
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"x2MinPin": -1,
"y2MinPin": -1,
"x2MaxPin": -1,
"y2MaxPin": -1,
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": -1,
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "M25",
"pauseEndCommands": "M24",
"distortionCorrection": "1",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 0,
"filamentChangeYPos": 0,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 2,
"filamentChangeLongRetract": 250,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "1",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"jamMethod": 1,
"primaryPort": 0,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"invertEndstop": "0",
"minEndstop": "1",
"endstopPullup": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 999999,
"zHomeYPos": 999999,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "1",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"zProbeDelay": 0,
"uiBedCoating": "1",
"langEN": "1",
"langDE": "1",
"langNL": "1",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"langRU": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"laserWarmupTime": 0,
"defaultPrinterMode": 0,
"laserPwmMax": 255,
"laserWatt": 2,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"cncPwmMax": 255,
"cncRpmMax": 8000,
"cncSafeZ": 150,
"startupGCode": ";Home G28 G1 X0 Y-100 Z030 F5000 ;Prime the extruder G92 E0 G1 F200 E30 G92 E0",
"jsonOutput": "0",
"bedLevelingMethod": 0,
"bedCorrectionMethod": 0,
"bedLevelingGridSize": 5,
"bedLevelingRepetitions": 5,
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"keepAliveInterval": 2000,
"moveXWhenHomed": "0",
"moveYWhenHomed": "0",
"moveZWhenHomed": "0",
"preheatTime": 30000,
"multiZEndstopHoming": "0",
"z2MinMaxPin": -1,
"z2MinMaxEndstop": 0,
"extruderIsZProbe": "0",
"boardFanMinSpeed": 0,
"doorPin": -1,
"doorEndstop": 0,
"zhomePreRaise": 0,
"zhomePreRaiseDistance": 10,
"dualXResolution": "0",
"x2axisStepsPerMM": 100,
"coolerPWMSpeed": 0,
"maxFanPWM": 255,
"raiseZOnToolchange": 0,
"distortionLimitTo": 2,
"automaticPowerup": 0,
"hasTMC2130": "0",
"TMC2130Sensorless": "0",
"TMC2130Steathchop": "1",
"TMC2130Interpolate256": "1",
"TMC2130PWMAmpl": 255,
"TMC2130PWMGrad": 1,
"TMC2130PWMAutoscale": "1",
"TMC2130PWMFreq": 2,
"TMC2130CSX": -1,
"TMC2130CSY": -1,
"TMC2130CSZ": -1,
"TMC2130CSE0": -1,
"TMC2130CSE1": -1,
"TMC2130CSE2": -1,
"TMC2130CSE3": -1,
"TMC2130CSE4": -1,
"TMC2130CurrentX": 1000,
"TMC2130CurrentY": 1000,
"TMC2130CurrentZ": 1000,
"TMC2130CurrentE0": 1000,
"TMC2130CurrentE1": 1000,
"TMC2130CurrentE2": 1000,
"TMC2130CurrentE3": 1000,
"TMC2130CurrentE4": 1000,
"microstepX": 16,
"microstepY": 16,
"microstepZ": 16,
"microstepE0": 16,
"microstepE1": 16,
"microstepE2": 16,
"microstepE3": 16,
"microstepE4": 16,
"parkPosX": 0,
"parkPosY": 0,
"parkPosZ": 10,
"emergencyParser": -1,
"hostRescue": "1",
"MAX31855SwCS": -1,
"MAX31855SwCLK": -1,
"tempGain": "1",
"hasMAX6675": false,
"hasMAX31855": false,
"hasMAX31855SW": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 100.4,
"primaryPortName": ""
