Hello,
i can't provide full gcodes log publicly and i don't think gcodes are the issues as all the gcodes were running without problem with Repetier server 1.4.2 before the update.
- is there a way to download back this 1.4.2 version and roll back ?
This morning i came back and almost all the printers were disconnected.
Note that i't's not just disconnected where i could deactivate and reactivate the printer:
No no no.
it's like repetier does something like a reset command / close connection (perhaps the ping pong mode around slow command ..? Ping pong mode is deactivated in the printers settings) to the printer after each print (and sometimes even during the print !)
so the printer get stuck and even its own duet web interface is not even accessible.
that's why i have to turn Off/on the printer and this morning had to do it on almost all the printers on this server !
So i suppect something new in the way the server handle the connection with the duet that completely brick the duet.
here is the server logs of this night when this happens :
2023-02-15 21:52:14: Print of PLT_OSL_12_0.35mm_PLA_4h17m_211.12g on printer COREXY 16 finished. Send 477356 lines. Printing time: 5:33:11
2023-02-15 23:02:09: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-15 23:02:09: Connection closed: COREXY 20
2023-02-16 00:09:33: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 08 finished. Send 287136 lines. Printing time: 8:19:44
2023-02-16 00:09:40: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 09 finished. Send 287136 lines. Printing time: 8:19:32
2023-02-16 00:09:44: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 06 finished. Send 287136 lines. Printing time: 8:20:27
2023-02-16 00:11:00: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:11:00: Connection closed: COREXY 08
2023-02-16 00:11:11: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:11:11: Connection closed: COREXY 06
2023-02-16 00:11:14: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:11:14: Connection closed: COREXY 09
2023-02-16 00:12:00: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 14 finished. Send 287136 lines. Printing time: 8:20:13
2023-02-16 00:12:03: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 12 finished. Send 287136 lines. Printing time: 8:20:47
2023-02-16 00:12:24: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 13 finished. Send 287136 lines. Printing time: 8:20:57
2023-02-16 00:13:28: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:13:28: Connection closed: COREXY 14
2023-02-16 00:13:31: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:13:31: Connection closed: COREXY 12
2023-02-16 00:13:52: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:13:52: Connection closed: COREXY 13
2023-02-16 00:13:54: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 18 finished. Send 287136 lines. Printing time: 8:20:28
2023-02-16 00:15:21: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:15:21: Connection closed: COREXY 18
2023-02-16 00:18:11: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 10 finished. Send 287136 lines. Printing time: 8:18:05
2023-02-16 00:19:39: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:19:39: Connection closed: COREXY 10
2023-02-16 00:20:30: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 02 finished. Send 287136 lines. Printing time: 8:18:25
2023-02-16 00:21:08: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 05 finished. Send 287136 lines. Printing time: 8:18:00
2023-02-16 00:21:57: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:21:57: Connection closed: COREXY 02
2023-02-16 00:22:37: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 00:22:37: Connection closed: COREXY 05
2023-02-16 00:59:55: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 25 finished. Send 287136 lines. Printing time: 9:02:58
2023-02-16 01:01:22: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:01:22: Connection closed: COREXY 25
2023-02-16 01:20:26: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 22 finished. Send 287136 lines. Printing time: 9:00:51
2023-02-16 01:21:39: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 21 finished. Send 287136 lines. Printing time: 9:04:42
2023-02-16 01:21:53: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:21:53: Connection closed: COREXY 22
2023-02-16 01:23:06: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:23:06: Connection closed: COREXY 21
2023-02-16 01:40:03: Print of 3x_VAS_ORI_15_0.35mm_PLA_7h29m_323.979g on printer COREXY 23 finished. Send 287136 lines. Printing time: 9:19:32
2023-02-16 01:41:31: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:41:31: Connection closed: COREXY 23
2023-02-16 01:47:04: Print of 4xVAS_WAV_15_0.35mm_PLA_8h59m_352.102g on printer COREXY 03 finished. Send 1140429 lines. Printing time: 9:58:34
2023-02-16 01:48:27: Print of 4xVAS_WAV_15_0.35mm_PLA_8h59m_352.102g on printer COREXY 07 finished. Send 1140429 lines. Printing time: 9:58:55
2023-02-16 01:48:33: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:48:33: Connection closed: COREXY 03
2023-02-16 01:49:56: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:49:56: Connection closed: COREXY 07
2023-02-16 01:57:37: Print of 4xVAS_WAV_15_0.35mm_PLA_8h59m_352.102g on printer COREXY 04 finished. Send 1140429 lines. Printing time: 9:56:31
2023-02-16 01:59:05: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 01:59:05: Connection closed: COREXY 04
2023-02-16 02:02:25: Print of VAS_ISH_20+2X_VAS_ORI_15_0.35mm_PLA_8h32m_343.502g on printer COREXY 24 finished. Send 1084460 lines. Printing time: 10:06:22
2023-02-16 02:03:54: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 02:03:54: Connection closed: COREXY 24
2023-02-16 02:39:51: Print of 2_VAS_OND_BOT_25_PLA_8h57m_450g on printer COREXY 17 finished. Send 723327 lines. Printing time: 10:46:47
2023-02-16 02:58:08: Print of 2_VAS_OND_BOT_25_PLA_8h57m_450g on printer COREXY 19 finished. Send 723327 lines. Printing time: 10:43:45
2023-02-16 03:21:21: Print of VAS_ISH_20+2X_VAS_ORI_15_0.35mm_PLA_8h32m_343.502g on printer COREXY 27 finished. Send 1084460 lines. Printing time: 11:23:57
2023-02-16 03:23:14: error: Reading conection failed: Operation timed out. Closing connection.
2023-02-16 03:23:14: Connection closed: COREXY 27
2023-02-16 07:26:16: Print of Terre dombres COREXY_0.35mm_PLA_11h8m_431.426g on printer COREXY 11 finished. Send 778990 lines. Printing time: 15:35:19
2023-02-16 07:38:16: Print of VAS_WAV_30_0.35mm_PLA_12h52m_496.855g on printer COREXY 26 finished. Send 1608777 lines. Printing time: 15:32:35
And here is the end of the log of the print of the COREXY 27 of this night causing the connection close and duet brick:
Send:3:21:21.180: N114267 M117 S"ETE 00:00:57"
Send:3:21:21.180: N114268 G1 X397.788 Y100.449 E0.07996
Send:3:21:21.181: N114269 G1 E-0.8 F3600
Send:3:21:21.181: N114270 M107
Recv:3:21:21.204: ok
Send:3:21:21.204: N114271 G91 ; relative positioning
Send:3:21:21.330: N114272 M408 S2
Recv:3:21:21.351: ok
Send:3:21:21.351: N114273 G1 Z+10 E-2 Y+10 F250 ;move Z up a bit and retract filament even more
Send:3:21:21.351: N114274 G90 ; absolute positionning
Send:3:21:21.351: N114275 G1 X0 Y500 F9000 ; Move Head Xmin Ymax
Send:3:21:21.352: N114276 G1 Z480 F600 ; Move Z max
Recv:3:21:21.352: ok
Send:3:21:21.352: N114277 M104 S0 ; turn off extruder
Recv:3:21:21.353: ok
Send:3:21:21.353: N114278 M140 S0 ; turn off bed
Recv:3:21:21.541: ok
Recv:3:21:21.613: ok
Recv:3:21:21.614: ok
Recv:3:21:21.616: ok
Recv:3:21:21.618: {"status":"B","coords":{"axesHomed":[1,1,1],"wpl":1,"xyz":[397.788,100.449,150.000],"machine":[396.917,92.155,150.000],"extr":[124189.9]},"speeds":{"requested":34.3,"top":34.3},"currentTool":0,"output":{"message":"S\"ETE 00:00:57\""},"params":{"atxPower":-1,"fanPercent":[0,0,0,0],"speedFactor":70.0,"extrFactors":[100.0],"babystep":0.000},"sensors":{"probeValue":0,"fanRPM":[-1,-1,-1,-1]},"temps":{"bed":{"current":54.9,"active":55.0,"standby":0.0,"state":2,"heater":0},"current":[54.9,195.2],"state":[2,2],"tools":{"active":[[195.0]],"standby":[[195.0]]},"extra":[{"name":"Bed","temp":54.9},{"name":"Hotend","temp":195.2}]},"time":42722.0}
Recv:3:21:21.618: ok
Recv:3:21:21.642: ok
Send:3:21:21.642: Slow command added:M400 ; Wait for current moves to finish, clearing the buffer
Send:3:21:21.642: N114279 M400 ; Wait for current moves to finish, clearing the buffer
Recv:3:21:21.643: ok
Send:3:21:21.643: N114280 M104 T0 S0 ; Disable extruder
Send:3:21:21.643: N114281 M140 S0 ; Disable bed
Send:3:21:21.643: N114282 G1 X0 Y0 F9000
Send:3:21:21.723: @stopLog
