Yes, use a desired-state workflow:
Export the running config from the device or service (for example, show/run or read live config files).
Compare it to your tool's model, merge changes, and then update the config.
Apply and reload with a safe rollback, using backup and version control.
If the tool does not support import, do a one-time “adopt existing” by parsing the live config into the tool's templates and variables. After that, manage it only through the tool. For related electronics modules and wiring accessories, check EnrgTech.
