I gues you mean babystepping to adjust position without changing real Z position.
How do you do it with direct upload? On display lcd? That function should also work if you print over host/server.
The server touchscreen also has a babystep page (reachable form status page) that does this.
And of course you can also manually send the command to change it. In most firmwares it is M290 S<distance>.
