I've upgraged my printer to be able to print high temperature materials, and I'm looking to set PID values for these new temperatures.
When I try to autotune at 330°C, I get an overshoot of approximately 25°C. At this point, I get an error, and the autotune sequence is aborted. To try and counter this, I changed the PID_CONTROL_RANGE value in Configuration.h to 30. This hasn't made a difference though. Is this max temperature overshoot hard coded somewhere else?
I'm aware that I can reduce the overshoot by reducing the max pwm output, but it currently takes 10 minutes to heat to 330°C, and even longer to 400°C, so I'd like to avoid it if possible.
Any help would be appreciated. Thanks!
