I'm attempting to level the bed on my Kossel Clear delta printer running 1.0.4-dev of the firmware. The heated bed has all four corners mounted on springs and their is a rectangle of glass placed on top of the heated bed. Using a straightedge and feeler gauges I have determined that the maximum un-flatness of the glass along the Y axis is 0.05 mm at the origin.
When I then move the extruder hotend from 0,90, to the origin, to 0,-90, I measure the three respective distances between the hotend nozzle tip and the glass as 0.21 mm, 0.51 mm, and 0.15 mm. The Z axis is set to 0.2 mm during all of these movements and measurements. I can repeat the motions and get the same measurements.
Since these measurements disagree with the measured flatness of the glass, which firmware parameters should I be looking at? Which parameters are most likely related to this deviation in positioning? I've already measured for Alpha and for Delta Radius.
The current EEPROM values are:
ttyACM0 PC> M205
SENDING:M205
EPR:0 1028 0 Language
EPR:2 75 230400 Baudrate
EPR:3 129 0.473 Filament printed [m]
EPR:2 125 955 Printer active [s]
EPR:2 79 0 Max. inactive time [ms,0=off]
EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
EPR:3 11 80.0000 Steps per mm
EPR:3 23 200.000 Max. feedrate [mm/s]
EPR:3 35 40.000 Homing feedrate [mm/s]
EPR:3 39 20.000 Max. jerk [mm/s]
EPR:3 133 0.000 X min pos [mm]
EPR:3 137 0.000 Y min pos [mm]
EPR:3 141 0.000 Z min pos [mm]
EPR:3 145 200.000 X max length [mm]
EPR:3 149 200.000 Y max length [mm]
EPR:3 153 263.200 Z max length [mm]
EPR:3 1056 0.000 Park position X [mm]
EPR:3 1060 0.000 Park position Y [mm]
EPR:3 1064 10.000 Park position Z raise [mm]
EPR:1 891 70 Segments/s for travel
EPR:1 889 180 Segments/s for printing
EPR:3 59 997.000 Acceleration [mm/s2]
EPR:3 71 1000.000 Travel acceleration [mm/s2]
EPR:3 881 288.000 Diagonal rod length [mm]
EPR:3 885 156.000 Horizontal rod radius at 0,0 [mm]
EPR:3 925 100.000 Max printable radius [mm]
EPR:1 893 164 Tower X endstop offset [steps]
EPR:1 895 110 Tower Y endstop offset [steps]
EPR:1 897 0 Tower Z endstop offset [steps]
EPR:3 901 210.000 Alpha A(210):
EPR:3 905 330.000 Alpha B(330):
EPR:3 909 90.000 Alpha C(90):
EPR:3 913 0.000 Delta Radius A(0):
EPR:3 917 2.000 Delta Radius B(0):
EPR:3 921 1.000 Delta Radius C(0):
EPR:3 933 0.000 Corr. diagonal A [mm]
EPR:3 937 0.000 Corr. diagonal B [mm]
EPR:3 941 0.000 Corr. diagonal C [mm]
EPR:3 1024 0.000 Coating thickness [mm]
EPR:1 1048 55 Bed Preheat temp. [degC]
EPR:0 106 0 Bed Heat Manager [0-3]
EPR:0 107 255 Bed PID drive max
EPR:0 124 80 Bed PID drive min
EPR:3 108 196.000 Bed PID P-gain
EPR:3 112 33.000 Bed PID I-gain
EPR:3 116 290.000 Bed PID D-gain
EPR:0 120 255 Bed PID max value [0-255]
EPR:0 1020 0 Enable retraction conversion [0/1]
EPR:3 992 3.000 Retraction length [mm]
EPR:3 1000 40.000 Retraction speed [mm/s]
EPR:3 1004 0.000 Retraction z-lift [mm]
EPR:3 1008 0.000 Extra extrusion on undo retract [mm]
EPR:3 1016 20.000 Retraction undo speed
EPR:3 200 100.000 Extr.1 steps per mm
EPR:3 204 50.000 Extr.1 max. feedrate [mm/s]
EPR:3 208 40.000 Extr.1 start feedrate [mm/s]
EPR:3 212 3000.000 Extr.1 acceleration [mm/s2]
EPR:1 294 190 Extr.1 Preheat temp. [degC]
EPR:0 216 1 Extr.1 heat manager [0-3]
EPR:0 217 140 Extr.1 PID drive max
EPR:0 245 60 Extr.1 PID drive min
EPR:3 218 7.0000 Extr.1 PID P-gain/dead-time
EPR:3 222 1.0800 Extr.1 PID I-gain
EPR:3 226 114.0000 Extr.1 PID D-gain
EPR:0 230 255 Extr.1 PID max value [0-255]
EPR:2 231 0 Extr.1 X-offset [steps]
EPR:2 235 0 Extr.1 Y-offset [steps]
EPR:2 290 0 Extr.1 Z-offset [steps]
EPR:1 239 1 Extr.1 temp. stabilize time [s]
EPR:1 250 150 Extr.1 temp. for retraction when heating [degC]
EPR:1 252 0 Extr.1 distance to retract when heating [mm]
EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
