petertn It is planed in the future to integrate devices such XTool d1 Pro, Atomstack, Orthur ... laser engraver machines into Repetier server? Will be good, because a lot of people using 3D printers are using engravers too. Tnx
Repetier As long as they use a 3d printer firmware they can use it as well to send the commands. Preview is not correct here but that would be all.For the general laser cutter/engraver I'm not sure they are using all an open interface standard. I have one and that one is surely only working with it's own mobile app. Especially for engraving you need solutions that transfer many data so own formats are more likely here. Just for cutting a g-code like interpreter would work great, but in combination you need a fast solution.
