Sorry, my bad. Here it is:
Sep 21 14:47:22 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 21 14:47:22 Repetier-Server systemd[1]: Starting Time & Date Service...
Sep 21 14:47:22 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 21 14:47:22 Repetier-Server systemd[1]: Started Time & Date Service.
Sep 21 14:47:43 Repetier-Server wpa_supplicant[471]: wlan0: Failed to initiate sched scan
Sep 21 14:48:23 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 21 14:48:23 Repetier-Server systemd[1]: Starting Time & Date Service...
Sep 21 14:48:23 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 21 14:48:23 Repetier-Server systemd[1]: Started Time & Date Service.
Sep 21 14:48:46 Repetier-Server wpa_supplicant[471]: wlan0: Failed to initiate sched scan
Sep 21 14:49:24 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 21 14:49:24 Repetier-Server systemd[1]: Starting Time & Date Service...
Sep 21 14:49:24 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 21 14:49:24 Repetier-Server systemd[1]: Started Time & Date Service.
Sep 21 14:49:34 Repetier-Server dhclient[472]: receive_packet failed on eth0: Network is down
Sep 21 14:49:34 Repetier-Server dhclient[472]: DHCPREQUEST of 192.168.1.121 on eth0 to 192.168.1.1 port 67
Sep 21 14:49:34 Repetier-Server dhcpcd[661]: eth0: carrier lost
Sep 21 14:49:34 Repetier-Server dhclient[472]: send_packet: Network is unreachable
Sep 21 14:49:34 Repetier-Server NetworkManager[354]: <info> [1663771774.6811] device (eth0): state change: activated -> unmanaged (reason 'removed') [100 10 36]
Sep 21 14:49:34 Repetier-Server kernel: [27513.884540] usb usb1-port1: disabled by hub (EMI?), re-enabling...
Sep 21 14:49:34 Repetier-Server kernel: [27513.884567] usb 1-1: USB disconnect, device number 2
Sep 21 14:49:34 Repetier-Server kernel: [27513.884579] usb 1-1.1: USB disconnect, device number 3
Sep 21 14:49:34 Repetier-Server kernel: [27513.885073] smsc95xx 1-1.1:1.0 eth0: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
Sep 21 14:49:34 Repetier-Server kernel: [27513.885251] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Sep 21 14:49:34 Repetier-Server dhclient[472]: send_packet: please consult README file regarding broadcast address.
Sep 21 14:49:34 Repetier-Server dhclient[472]: dhclient.c:2612: Failed to send 300 byte long packet over fallback interface.
Sep 21 14:49:34 Repetier-Server avahi-daemon[367]: Interface eth0.IPv6 no longer relevant for mDNS.
Sep 21 14:49:34 Repetier-Server avahi-daemon[367]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::e21a:ac6a:b026:fb4c.
Sep 21 14:49:34 Repetier-Server avahi-daemon[367]: Interface eth0.IPv4 no longer relevant for mDNS.
Sep 21 14:49:34 Repetier-Server avahi-daemon[367]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.1.121.
Sep 21 14:49:34 Repetier-Server avahi-daemon[367]: Withdrawing address record for fe80::e21a:ac6a:b026:fb4c on eth0.
Sep 21 14:49:34 Repetier-Server avahi-daemon[367]: Withdrawing address record for 192.168.1.121 on eth0.
Sep 21 14:49:34 Repetier-Server ModemManager[330]: <info> (net/eth0): released by modem /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1
Sep 21 14:49:34 Repetier-Server NetworkManager[354]: <info> [1663771774.7267] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 472
Sep 21 14:49:34 Repetier-Server NetworkManager[354]: <info> [1663771774.7269] dhcp4 (eth0): state changed bound -> done
Sep 21 14:49:34 Repetier-Server NetworkManager[354]: <info> [1663771774.7289] dns-mgr: Removing DNS information from /sbin/resolvconf
Sep 21 14:49:34 Repetier-Server MJPG-streamer [442]: Error grabbing frames
Sep 21 14:49:34 Repetier-Server kernel: [27513.955524] usb 1-1.3: USB disconnect, device number 4
Sep 21 14:49:34 Repetier-Server kernel: [27513.980711] usb 1-1.4: USB disconnect, device number 5
Sep 21 14:49:34 Repetier-Server MJPG-streamer [417]: Error grabbing frames
Sep 21 14:49:34 Repetier-Server kernel: [27513.987123] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Sep 21 14:49:34 Repetier-Server kernel: [27513.987200] ch341 1-1.4:1.0: device disconnected
Sep 21 14:49:34 Repetier-Server kernel: [27513.989603] usb 1-1.5: USB disconnect, device number 6
Sep 21 14:49:34 Repetier-Server dhcpcd[661]: eth0: deleting address fe80::ecb0:1d52:f5b4:b27
Sep 21 14:49:34 Repetier-Server dhcpcd[661]: eth0: deleting default route via 192.168.1.1
Sep 21 14:49:34 Repetier-Server dhcpcd[661]: eth0: deleting route to 192.168.1.0/24
Sep 21 14:49:35 Repetier-Server kernel: [27514.204448] Indeed it is in host mode hprt0 = 00001501
Sep 21 14:49:35 Repetier-Server dhcpcd[661]: eth0: removing interface
Sep 21 14:49:35 Repetier-Server kernel: [27514.414414] usb 1-1: new high-speed USB device number 7 using dwc_otg
Sep 21 14:49:35 Repetier-Server kernel: [27514.414493] Indeed it is in host mode hprt0 = 00001101
Sep 21 14:49:35 Repetier-Server kernel: [27514.654564] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Sep 21 14:49:35 Repetier-Server kernel: [27514.654571] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 21 14:49:35 Repetier-Server kernel: [27514.654959] hub 1-1:1.0: USB hub found
Sep 21 14:49:35 Repetier-Server kernel: [27514.655006] hub 1-1:1.0: 5 ports detected
Sep 21 14:49:35 Repetier-Server kernel: [27514.974439] usb 1-1.1: new high-speed USB device number 8 using dwc_otg
Sep 21 14:49:35 Repetier-Server kernel: [27515.104865] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Sep 21 14:49:35 Repetier-Server kernel: [27515.104881] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 21 14:49:35 Repetier-Server NetworkManager[354]: Too few arguments.
Sep 21 14:49:35 Repetier-Server kernel: [27515.115593] smsc95xx v1.0.6
Sep 21 14:49:35 Repetier-Server mtp-probe: checking bus 1, device 8: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Sep 21 14:49:35 Repetier-Server NetworkManager[354]: <info> [1663771775.9550] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 21 14:49:35 Repetier-Server NetworkManager[354]: <info> [1663771775.9585] manager: NetworkManager state is now DISCONNECTED
Sep 21 14:49:35 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Sep 21 14:49:35 Repetier-Server systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 21 14:49:36 Repetier-Server mtp-probe: bus: 1, device: 8 was not an MTP device
Sep 21 14:49:36 Repetier-Server kernel: [27515.208532] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a3:d9:e1
Sep 21 14:49:36 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 21 14:49:36 Repetier-Server systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 21 14:49:36 Repetier-Server nm-dispatcher: req:1 'connectivity-change': new request (1 scripts)
Sep 21 14:49:36 Repetier-Server nm-dispatcher: req:1 'connectivity-change': start running ordered scripts...
Sep 21 14:49:36 Repetier-Server dhcpcd[661]: eth0: waiting for carrier
Sep 21 14:49:36 Repetier-Server kernel: [27515.375518] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Sep 21 14:49:36 Repetier-Server kernel: [27515.375745] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sep 21 14:49:36 Repetier-Server kernel: [27515.514420] usb 1-1.3: new high-speed USB device number 9 using dwc_otg
Sep 21 14:49:36 Repetier-Server nm-dispatcher: req:2 'down' [eth0]: new request (1 scripts)
Sep 21 14:49:36 Repetier-Server nm-dispatcher: req:2 'down' [eth0]: start running ordered scripts...
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3560] devices removed (path: /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/net/eth0, iface: eth0)
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3595] devices added (path: /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/net/eth0, iface: eth0)
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3596] device added (path: /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/net/eth0, iface: eth0): no ifupdown configuration found.
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3703] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/4)
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3744] keyfile: add connection in-memory (fe595fac-107f-3bf6-8482-4db4be1ade3e,"Wired connection 1")
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3768] settings: (eth0): created default wired connection 'Wired connection 1'
Sep 21 14:49:36 Repetier-Server NetworkManager[354]: <info> [1663771776.3804] device (eth0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Sep 21 14:49:36 Repetier-Server kernel: [27515.591550] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sep 21 14:49:36 Repetier-Server kernel: [27515.674912] usb 1-1.3: New USB device found, idVendor=1908, idProduct=2311
Sep 21 14:49:36 Repetier-Server kernel: [27515.674922] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 21 14:49:36 Repetier-Server kernel: [27515.674926] usb 1-1.3: Product: USB2.0 PC CAMERA
Sep 21 14:49:36 Repetier-Server kernel: [27515.674930] usb 1-1.3: Manufacturer: Generic
Sep 21 14:49:36 Repetier-Server kernel: [27515.678881] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
Sep 21 14:49:36 Repetier-Server kernel: [27515.679323] uvcvideo 1-1.3:1.0: Entity type for entity Processing 2 was not initialized!
Sep 21 14:49:36 Repetier-Server kernel: [27515.679330] uvcvideo 1-1.3:1.0: Entity type for entity Camera 1 was not initialized!
Sep 21 14:49:36 Repetier-Server kernel: [27515.679792] input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input2
Sep 21 14:49:36 Repetier-Server mtp-probe: checking bus 1, device 9: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
Sep 21 14:49:36 Repetier-Server mtp-probe: bus: 1, device: 9 was not an MTP device
Sep 21 14:49:36 Repetier-Server systemd[1]: Stopped mjpg_streamer for picam.
Sep 21 14:49:36 Repetier-Server systemd[1]: Stopping mjpg_streamer for picam...
Sep 21 14:49:36 Repetier-Server systemd[1]: Started mjpg_streamer for picam.
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: Start from directory /usr/local/Repetier-Setup/bin
Sep 21 14:49:36 Repetier-Server kernel: [27515.774500] usb 1-1.4: new full-speed USB device number 10 using dwc_otg
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: Testing active webcams in /dev/v4l/by-id/
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: Starting webcam /dev/v4l/by-id/usb-Generic_USB2.0_PC_CAMERA-video-index0
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: Webcam does not support MJPG - using slower YUYV instead!
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: Best resolution: 640 x 480 at 30
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: Starting usb-Generic_USB2.0_PC_CAMERA-video-index0 on port 8080
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video0 --fps 30 -q 85 -r 640x480 -y " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080 -w /usr/local/share/mjpg-streamer/www" -b
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26822]: starting application
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26822]: enabling daemon mode
Sep 21 14:49:36 Repetier-Server startAllCams[26801]: enabling daemon modeforked to background (26824)
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: Using V4L2 device.: /dev/video0
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: Desired Resolution: 640 x 480
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: Frames Per Second.: 30
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: Format............: YUYV
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: JPEG Quality......: 85
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: TV-Norm...........: DEFAULT
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: HTTP TCP port........: 8080
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: HTTP Listen Address..: (null)
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: username:password....: disabled
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: commands.............: enabled
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
Sep 21 14:49:36 Repetier-Server MJPG-streamer [26824]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
Sep 21 14:49:36 Repetier-Server kernel: [27515.917520] usb 1-1.4: New USB device found, idVendor=1a86, idProduct=7523
Sep 21 14:49:36 Repetier-Server kernel: [27515.917527] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Sep 21 14:49:36 Repetier-Server kernel: [27515.917531] usb 1-1.4: Product: USB2.0-Serial
Sep 21 14:49:36 Repetier-Server kernel: [27515.918826] ch341 1-1.4:1.0: ch341-uart converter detected
Sep 21 14:49:36 Repetier-Server kernel: [27515.921672] usb 1-1.4: ch341-uart converter now attached to ttyUSB0
Sep 21 14:49:36 Repetier-Server mtp-probe: checking bus 1, device 10: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4"
Sep 21 14:49:36 Repetier-Server mtp-probe: bus: 1, device: 10 was not an MTP device
Sep 21 14:49:36 Repetier-Server systemd-udevd[26794]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Sep 21 14:49:36 Repetier-Server kernel: [27516.014486] usb 1-1.5: new high-speed USB device number 11 using dwc_otg
Sep 21 14:49:37 Repetier-Server kernel: [27516.356434] usb 1-1.5: New USB device found, idVendor=046d, idProduct=0825
Sep 21 14:49:37 Repetier-Server kernel: [27516.356443] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Sep 21 14:49:37 Repetier-Server kernel: [27516.356448] usb 1-1.5: SerialNumber: 7BB5DAE0
Sep 21 14:49:37 Repetier-Server kernel: [27516.358188] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
Sep 21 14:49:37 Repetier-Server kernel: [27516.448378] uvcvideo 1-1.5:1.0: Entity type for entity Extension 4 was not initialized!
Sep 21 14:49:37 Repetier-Server kernel: [27516.448388] uvcvideo 1-1.5:1.0: Entity type for entity Extension 6 was not initialized!
Sep 21 14:49:37 Repetier-Server kernel: [27516.448394] uvcvideo 1-1.5:1.0: Entity type for entity Extension 7 was not initialized!
Sep 21 14:49:37 Repetier-Server kernel: [27516.448399] uvcvideo 1-1.5:1.0: Entity type for entity Processing 2 was not initialized!
Sep 21 14:49:37 Repetier-Server kernel: [27516.448404] uvcvideo 1-1.5:1.0: Entity type for entity Extension 3 was not initialized!
Sep 21 14:49:37 Repetier-Server kernel: [27516.448409] uvcvideo 1-1.5:1.0: Entity type for entity Camera 1 was not initialized!
Sep 21 14:49:37 Repetier-Server kernel: [27516.449012] input: UVC Camera (046d:0825) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input3
Sep 21 14:49:37 Repetier-Server dhcpcd[661]: eth0: carrier acquired
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.5712] device (eth0): link connected
Sep 21 14:49:37 Repetier-Server kernel: [27516.778665] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sep 21 14:49:37 Repetier-Server kernel: [27516.781020] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.5808] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed') [20 30 40]
Sep 21 14:49:37 Repetier-Server dhcpcd[661]: eth0: IAID eb:a3:d9:e1
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.5856] policy: auto-activating connection 'Wired connection 1'
Sep 21 14:49:37 Repetier-Server dhcpcd[661]: eth0: adding address fe80::ecb0:1d52:f5b4:b27
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.5935] device (eth0): Activation: starting connection 'Wired connection 1' (fe595fac-107f-3bf6-8482-4db4be1ade3e)
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.5969] device (eth0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.5979] manager: NetworkManager state is now CONNECTING
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.6040] device (eth0): state change: prepare -> config (reason 'none') [40 50 0]
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.6088] device (eth0): state change: config -> ip-config (reason 'none') [50 70 0]
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.6125] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Sep 21 14:49:37 Repetier-Server NetworkManager[354]: <info> [1663771777.6224] dhcp4 (eth0): dhclient started with pid 26834
Sep 21 14:49:37 Repetier-Server dhcpcd[661]: eth0: soliciting an IPv6 router
Sep 21 14:49:37 Repetier-Server dhclient[26834]: DHCPREQUEST of 192.168.1.121 on eth0 to 255.255.255.255 port 67
Sep 21 14:49:37 Repetier-Server dhcpcd[661]: eth0: rebinding lease of 192.168.1.121
Sep 21 14:49:38 Repetier-Server ModemManager[330]: <info> Couldn't check support for device at '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1': not supported by any plugin
Sep 21 14:49:38 Repetier-Server kernel: [27517.790848] usb 1-1.5: set resolution quirk: cval->res = 384
Sep 21 14:49:38 Repetier-Server mtp-probe: checking bus 1, device 11: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
Sep 21 14:49:38 Repetier-Server mtp-probe: bus: 1, device: 11 was not an MTP device
Sep 21 14:49:38 Repetier-Server systemd[1]: Stopping mjpg_streamer for picam...
Sep 21 14:49:38 Repetier-Server systemd[1]: Stopped mjpg_streamer for picam.
Sep 21 14:49:38 Repetier-Server systemd[1]: Started mjpg_streamer for picam.
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Start from directory /usr/local/Repetier-Setup/bin
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Testing active webcams in /dev/v4l/by-id/Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Starting webcam /dev/v4l/by-id/usb-046d_0825_7BB5DAE0-video-index0
Sep 21 14:49:38 Repetier-Server systemd-udevd[26845]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Best resolution: 640 x 480 at 30
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Starting usb-046d_0825_7BB5DAE0-video-index0 on port 8081
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 30 -q 85 -r 640x480 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8081 -w /usr/local/share/mjpg-streamer/www" -b
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26877]: starting application
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26877]: enabling daemon mode
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: enabling daemon modeStarting webcam /dev/v4l/by-id/usb-Generic_USB2.0_PC_CAMERA-video-index0
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: forked to background (26879)
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26879]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26879]: Using V4L2 device.: /dev/video1
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26879]: Desired Resolution: 640 x 480
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26879]: Frames Per Second.: 30
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26879]: Format............: JPEG
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26879]: TV-Norm...........: DEFAULT
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Webcam does not support MJPG - using slower YUYV instead!
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: Starting usb-Generic_USB2.0_PC_CAMERA-video-index0 on port 8080
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video0 --fps 30 -q 85 -r 640x480 -y " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080 -w /usr/local/share/mjpg-streamer/www" -b
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26891]: starting application
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26891]: enabling daemon mode
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Sep 21 14:49:38 Repetier-Server startAllCams[26855]: enabling daemon modeforked to background (26893)
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: Using V4L2 device.: /dev/video0
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: Desired Resolution: 640 x 480
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: Frames Per Second.: 30
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: Format............: YUYV
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: JPEG Quality......: 85
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: TV-Norm...........: DEFAULT
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: HTTP TCP port........: 8080
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: HTTP Listen Address..: (null)
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: username:password....: disabled
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: commands.............: enabled
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
Sep 21 14:49:38 Repetier-Server MJPG-streamer [26893]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: HTTP TCP port........: 8081
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: HTTP Listen Address..: (null)
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: username:password....: disabled
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: commands.............: enabled
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
Sep 21 14:49:39 Repetier-Server MJPG-streamer [26879]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
Sep 21 14:49:39 Repetier-Server avahi-daemon[367]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::e21a:ac6a:b026:fb4c.
Sep 21 14:49:39 Repetier-Server avahi-daemon[367]: New relevant interface eth0.IPv6 for mDNS.
Sep 21 14:49:39 Repetier-Server avahi-daemon[367]: Registering new address record for fe80::e21a:ac6a:b026:fb4c on eth0.*.
Sep 21 14:49:42 Repetier-Server dhcpcd[661]: eth0: probing address 192.168.1.121/24
Sep 21 14:49:42 Repetier-Server dhclient[26834]: DHCPREQUEST of 192.168.1.121 on eth0 to 255.255.255.255 port 67
Sep 21 14:49:42 Repetier-Server dhclient[26834]: DHCPACK of 192.168.1.121 from 192.168.1.1
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4429] dhcp4 (eth0): address 192.168.1.121
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4430] dhcp4 (eth0): plen 24 (255.255.255.0)
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4431] dhcp4 (eth0): gateway 192.168.1.1
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4431] dhcp4 (eth0): server identifier 192.168.1.1
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4432] dhcp4 (eth0): lease time 86400
Sep 21 14:49:42 Repetier-Server avahi-daemon[367]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.121.
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4432] dhcp4 (eth0): hostname 'Pi3iS_LAN'
Sep 21 14:49:42 Repetier-Server avahi-daemon[367]: New relevant interface eth0.IPv4 for mDNS.
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4433] dhcp4 (eth0): nameserver '192.168.1.1'
Sep 21 14:49:42 Repetier-Server avahi-daemon[367]: Registering new address record for 192.168.1.121 on eth0.IPv4.
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4433] dhcp4 (eth0): domain name 'homemesh'
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4434] dhcp4 (eth0): state changed unknown -> bound
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4482] device (eth0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4521] device (eth0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
Sep 21 14:49:42 Repetier-Server nm-dispatcher: req:3 'connectivity-change': new request (1 scripts)
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4543] device (eth0): state change: secondaries -> activated (reason 'none') [90 100 0]
Sep 21 14:49:42 Repetier-Server nm-dispatcher: req:3 'connectivity-change': start running ordered scripts...
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4554] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4804] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4811] policy: set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.4823] dns-mgr: Writing DNS information to /sbin/resolvconf
Sep 21 14:49:42 Repetier-Server dhclient[26834]: bound to 192.168.1.121 -- renewal in 42422 seconds.
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: Too few arguments.
Sep 21 14:49:42 Repetier-Server NetworkManager[354]: <info> [1663771782.5953] device (eth0): Activation: successful, device activated.
Sep 21 14:49:42 Repetier-Server nm-dispatcher: req:4 'up' [eth0]: new request (1 scripts)
Sep 21 14:49:42 Repetier-Server nm-dispatcher: req:4 'up' [eth0]: start running ordered scripts...
Sep 21 14:49:42 Repetier-Server systemd[1]: Reloading OpenBSD Secure Shell server.
Sep 21 14:49:43 Repetier-Server systemd[1]: Reloaded OpenBSD Secure Shell server.
Sep 21 14:49:43 Repetier-Server systemd[1]: Reloading OpenBSD Secure Shell server.
Sep 21 14:49:47 Repetier-Server dhcpcd[661]: eth0: leased 192.168.1.121 for 86400 seconds
Sep 21 14:49:47 Repetier-Server dhcpcd[661]: eth0: adding route to 192.168.1.0/24
Sep 21 14:49:47 Repetier-Server dhcpcd[661]: eth0: adding default route via 192.168.1.1
Sep 21 14:49:49 Repetier-Server NetworkManager[354]: <info> [1663771789.4602] device (wlan0): set-hw-addr: set MAC address to E2:E2:38:77:39:F8 (scanning)
Sep 21 14:49:49 Repetier-Server dhcpcd[661]: wlan0: new hardware address: e2:e2:38:77:39:f8
Sep 21 14:49:49 Repetier-Server kernel: [27528.671052] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Sep 21 14:49:49 Repetier-Server kernel: [27528.671064] brcmfmac: power management disabled
Sep 21 14:49:49 Repetier-Server NetworkManager[354]: <info> [1663771789.5662] device (wlan0): supplicant interface state: inactive -> disconnected
Sep 21 14:49:49 Repetier-Server NetworkManager[354]: <info> [1663771789.6016] device (wlan0): supplicant interface state: disconnected -> inactive
Sep 21 14:49:49 Repetier-Server wpa_supplicant[471]: wlan0: Reject scan trigger since one is already pending
Sep 21 14:49:51 Repetier-Server dhcpcd[661]: eth0: no IPv6 Routers available
Sep 21 14:50:25 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 21 14:50:25 Repetier-Server systemd[1]: Starting Time & Date Service...
Sep 21 14:50:25 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 21 14:50:25 Repetier-Server systemd[1]: Started Time & Date Service.
Sep 21 14:51:26 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 21 14:51:26 Repetier-Server systemd[1]: Starting Time & Date Service...
Sep 21 14:51:26 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 21 14:51:26 Repetier-Server systemd[1]: Started Time & Date Service.
Sep 21 14:51:56 Repetier-Server wpa_supplicant[471]: wlan0: Failed to initiate sched scan
Sep 21 14:52:27 Repetier-Server dbus[335]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 21 14:52:27 Repetier-Server systemd[1]: Starting Time & Date Service...
Sep 21 14:52:27 Repetier-Server dbus[335]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 21 14:52:27 Repetier-Server systemd[1]: Started Time & Date Service.
