BLTouch
Has anyone gotten this to work in Repetier Firmware?
I've seen a couple posts asking questions and a comment on the indiegogo page that someone was having trouble with it
«1
  • I have used one of these sensors in MarlinFirmware and it worked well.
    The only odd thing about the sensor is that to drop the pin down below the nozzle it is a servo movement (setting servo to 10 deg from memory. And 90 to raise it)
    BUT every single probe needs to have the servo called to 10 deg so the pin can drop down again..
    Is this how repetier works @repetier
  • No, repetier has a start and end command to enable/disable a probe but after that it assumes it works.
    But you can easily hack runZProbe to execute an additional gcode command if required:
    GCode::executeFString(PSTR("gcode"));
  • edited January 2016
    That worked! @repetier thank you for your time helping.
    Is there a way to add that sort of a "hack" to a G28 (Zxytz) I had a look at the code to try this but I am uncertain where would be an appropriate location to insert it.
    I am asking this because my printer has an enclosed chamber and it is hart for me to add z max endstop at the moment and I have parts I am needing to continue making for the next few weeks.
  • I guess homeZ would be the right function. There you have 2 moves down where you would need to add it.
  • i am looking to hook up a bltouch on my Printer too,
    could someone please explain me how to manage this with repetier Firmware?
    I am not sure where to "hack" runZProbe....
    @repetier, is it possible that you implement the feature on the next FW update?
  • The function to hack is in BedLeveling.cpp in latest version. Just put the hack in the first line of the code I guess. But I do not have the probe so I can not test and program. But I guess it is just some servo movement gcode you need. If that works I could add a per probe script in addition.
  • I am just looking at getting the BLTouch working on Repetier.  Is this hack still required, and has it been tested and proven to work?  Many thanks!
  • Have someone solved the Problem? Can you Post your ZProbe Settings?. Thx
  • I also would like a good tutorial on adding the BLTouch to Repetier. Repetier has got to be the worst firmware for finding good tutorials on....
  • Here are my settings:
    No hack required the probe releases itself after touching the bed.
  • After trying bltouch to work for 2 weeks I decided to opt it out. Now I purchased an 8mm inductive sensor and will try it.
    I had several problems with voltage, auto bed leveling, nozzle height. It works with Marlin but with Repetier I believe still needs some development.
  • I use bltouch with repetier and have no problems with it.
  • @MartinH could you share your configuration, or your how-to, it'll help few people like me :)
  • edited May 2017
    Hi.
    Attached is my config file that i am using with a BLtouch.
    Make sure you use the dev version of firmware
    Use homing option x y preheat Z
    set it to allways raise Z
    edit/ cant see the attachment so here's a link
    https://drive.google.com/file/d/0B7pWunHO-VN6NXFmXzRJNVVnbHc/view?usp=sharing
  • We had endless problems with BLTouch on 1.0.0dev, replaced with inductive sensor (as ZMIN/ZPROBE) and life became quite a bit more easy (or at least more reliably-behaved).  Still seeing some oddities w.r.t. G29 vs homing ZMIN but able to work around those by relying on ZHoming instead of "G29 S2"-ing.
  • I have done a tutorial on setting up the BLTouch, hope it can help someone.
  • Hi. Im trying to install a bltouch clone (3dtouch , is exactly the same) so I guessed this instructions shuld have worked for me. But Im havening something wrong and I cant find what it is. I have recompiled the eprom (configuration.h is atached) I uploaded, priter responds to mvements and commands. But following the video instructions I got to the point where I have to calibrate the probe/ noozle offset. I tried to execute the command M340 to move the probe up and down. I execute the commands as seen in the video and I get nothing, in the console I dont even get "unknown command", I just type the commands , enter, and nothing happens. I double checked the cofiguration.h config, my 3d touch is wired like this
    Any ideas what Im doing wrong?
    Thanks in advance
  • O partially solved it. For some reason my ramps board is not delivering 5V in the servo pin... I tried gettin 5V from the aux pins and now the 3d touch works, but still Im not bein able to complete the steps,I was able to measure the x/y offset, introduced that in the firmware, but I can not get the rest of the instructions, when I do a g32 step, I get an errer saying "23:06:16.984 : Error:Activating z-probe would lead to forbidden xy position: 20.700000, -11.60"
  • Tinchus2009, that "forbidden xy position" (especially the -11.60) indicates that your probe is located "behind" (at a greater Y position) than your extruder.
    As such, you need to adjust the Z-probe offset y to be AT LEAST 11.60 (how far from "HOME" [presumably 0,0] the probe is):
    Here, you'll see my setting for 105.990, meaning MY probe is 105.99mm away from my Y-Axis "home".
    If you stop to think about it, it makes sense...  The printer can't move the PROBE any closer to the zero "edge" (of the Y-Axis) than 11.60mm, so you need to update the EEPROM to reflect this offset.
    Same thing for the "Z-probe offset x"...  How far from the extruder is the probe (on the X-Axis).
    Hope that helps...
  • Hi
    I have a problem with bltouch  with rumba board
    i'v connected the bltouch into Zmin and EXP-3 2,4,and 6 pins (PWM2).
    Then I configured repetier like Pigeon shows in his tutorial
    In Servo configuration I don't know what to choose and I'v left Z min endstop
    After compiling ad writing it into the board the BLTouch don't response to any commands to test it.
    The compilation was ok
    Can anyone done bltouch with rumba and repetier?
  • here is a good video on connecting bltouch to a rumba board.
    https://www.youtube.com/watch?v=-4o6-8TgpNM
    servo 0 pin in your config needs to point to which digital pin the bltouch is connected,  so pin 5 as in the video.
  • edited May 2020
    I built a COREXY printer (Mega 2560+RAMPS 1.4) and followed the instruction from Pigeon, but the z-probe did not trigger any z-min signal. When it tried to obtain the z-offset, the bed just keep going and hitting the nozzle despite the z-probe had been retracted.
    Later I did manual testing with Command M119.
    There is no z-min level change on the following Z-probe command (Z-min remain Low)
    extend the probe: M340 S0 S700
    retract the probe: M340 S0 S1500
    M119
    endstops hit: x_min:H y_min:H z_min:L z_max:H Z-probe state:L
    When I loaded Marin 2.0.x on the system, it works. It can detect the triggering of the Z-min.
    The Z-Probe is connected to Z-Min with no pullup resistor.
    Here is my Configuration.h
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define XAXIS_STEPS_PER_MM 160
    #define YAXIS_STEPS_PER_MM 160
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 98.15
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 6.39
    #define EXT0_PID_I 0.24
    #define EXT0_PID_D 41.66
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 0.6
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_REHOME 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 180
    #define Y_MAX_LENGTH 180
    #define Z_MAX_LENGTH 130
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 170
    #define DISTORTION_YMAX 170
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 20
    #define HOMING_FEEDRATE_X 20
    #define HOMING_FEEDRATE_Y 20
    #define HOMING_FEEDRATE_Z 5
    #define HOMING_ORDER HOME_ORDER_ZXYTZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_PRE_RAISE_DISTANCE 5
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 90
    #define ZHOME_Y_POS 90
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define DOUBLE_STEP_DELAY 1 // time in microseconds
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 4
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 2
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "X3D XL CoreXY"
    #define UI_PRINTER_COMPANY "rctruck.pl"
    #define UI_AUTORETURN_TO_MENU_AFTER 60000
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_HEAD "MEI's 3D Printer"
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define NUM_MOTOR_DRIVERS 0
        "editMode": 2,
        "processor": 0,
        "baudrate": 250000,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 160,
        "yStepsPerMM": 160,
        "zStepsPerMM": 80,
        "xInvert": 0,
        "x2Invert": 0,
        "xInvertEnable": 0,
        "eepromMode": 2,
        "yInvert": 0,
        "y2Invert": 0,
        "yInvertEnable": 0,
        "zInvert": 0,
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 6.39,
                "pidI": 0.24,
                "pidD": 41.66,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 98.15,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 9,
        "uiController": 0,
        "xMinEndstop": 2,
        "yMinEndstop": 2,
        "zMinEndstop": 4,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 2,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 1,
        "xMaxSpeed": 200,
        "xHomingSpeed": 20,
        "xTravelAcceleration": 500,
        "xPrintAcceleration": 500,
        "yMaxSpeed": 200,
        "yHomingSpeed": 20,
        "yTravelAcceleration": 500,
        "yPrintAcceleration": 500,
        "zMaxSpeed": 20,
        "zHomingSpeed": 5,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 180,
        "yLength": 180,
        "zLength": 130,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 1,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": 0,
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "1",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_ZXYTZ",
        "featureController": 11,
        "uiPrinterName": "X3D XL CoreXY",
        "uiPrinterCompany": "rctruck.pl",
        "uiPagesDuration": 4000,
        "uiHeadline": "MEI's 3D Printer",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 60000,
        "featureKeys": "0",
        "uiEncoderSpeed": 2,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbeBedDistance": 10,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "0",
        "zProbeOnHigh": "1",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 0,
        "zProbeStartScript": "M340 P0 S700",
        "zProbeFinishedScript": "M340 P0 S1500",
        "featureAutolevel": "1",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 160,
        "zProbeY2": 20,
        "zProbeX3": 100,
        "zProbeY3": 160,
        "zProbeSwitchingDistance": 4,
        "zProbeRepetitions": 2,
        "zProbeMedian": "0",
        "zProbeEveryPoint": "",
        "sdSupport": "0",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 170,
        "distortionYMin": 10,
        "distortionYMax": 170,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 0.6,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 0,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 90,
        "zHomeYPos": 90,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 1,
        "zhomePreRaise": 0,
        "zhomePreRaiseDistance": 5,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "TMC2130CurrentX": 1000,
        "TMC2130CurrentY": 1000,
        "TMC2130CurrentZ": 1000,
        "TMC2130CurrentE0": 1000,
        "TMC2130CurrentE1": 1000,
        "TMC2130CurrentE2": 1000,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "maxHalfstepInterval": 1999,
        "uiAnimation": "0",
        "uiPresetBedTempPLA": 50,
        "uiPresetBedABS": 100,
        "uiPresetExtruderPLA": 188,
        "uiPresetExtruderABS": 232,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100.2,
        "primaryPortName": ""
  • M340 only sets servo timing which you use to set BLtouch mode.
    Signal with M119 will always be L because the signal only stays for 100ms on H and you are not fast enough when you trigger it. More important is if G30 stops going down when it triggers the probe. Try this in free air by hand for safety.
  • edited May 2020
    When I was testing with the bed yesterday with 1.0.3. After the sensor was touched with the bed and retracted, the bed kept going up and hit the nozzle. I have not tested it with my finger in mid-air. I will test 1.0.4 tonight.
    I am wondering, it is possible to put in logic in M119 to display the BLTouch/Zmin status like Marlin (Combination of pulse detection and current Servo PWM)?
  • You can enable end stop debugging. Bit value 64 enables it.
    M111 S70
    then you see every change of endstop. Use it only for debugging - too many changes in short time can crash firmware in debug mode.
  • Switched to debug level 70. Pressing the endstops did not show any debugging information (X, Y, or the 3DTouch).
    I went thought the menu to "Z-Calibration" -> Z probe height.
    https://vimeo.com/415060548
    As shown in the video, use the finger to push the sensor does not stop the bed from moving towards the nozzle.
  • #define Z_PROBE_PULLUP 1
    says you want a pullup while z min config says no pullup. Should be identical. I think you need no pullup as it is a electronic generated signal. Might be the reason or you are not connected to z min connector.
  • Set all Z endstop pullup to disable
    #define Z_PROBE_PULLUP 0
    Still the same problem.
    Zmin on RAMPS board is right under Zmax, it works correctly in Marlin, should it be connected somewhere else in Repetier firmware?
  • Just testing with the 1.0.3 firmware, the probe only fails when "Measure Probe Height". When manually triggered the autoleveling, the 3Dtouch sensor is triggered correctly.
    May I know how to use the "Measure Probe Height" function?
  • Endstops are not changed in 1.0.4 so strange it works in 1.0.3.
    Measure z probe height needs a block of known height. You make it hit the nozzle so end stop is not triggered. Then it measures z height and compares to entered correct height from block test and adjusts z probe height according to the difference. Not sure about the order of entering height but that is the concept of the function.
