calibration of XY after printing
edited August 11 in Motor Control
ran a few test prints of the 20mm cube measures 20mm for Z but 25mm for xy how / were do i place the calibration correction dont see a default axis per steps calibration for the corexy?
After reading and searching the internet found a fix i think the command is AXISCOMP_tanxy says 0 in my config
based on the test cube being square 20mm and mine is 25x25x20 the correction is 1.25
do i put 1.25 and replace the 0?
  • No, you just update steps per mm by 20/25. More likely is 1/sqrt(2) as correction factor.
