No Video Feed with a Webcam, only static Image [0.85]
Hello, I have the problem that I only see the static Image of the webcam and not the video feed. But when I go to the settings page I can see both, the image and the video. I use webcamXP to stream the image.
I have Repetier Server 0.85 running on Ubuntu.
  • Thanks. Have tested it and did also not get it working. Looks like the MJPG format differs somehow from mjpg_streamer generated source so our new handling seems to fail on this. Will look into this and fix it for 0.85.2.
    What is still working is if you use linux mjpg_streamer to create IP webcam stream. Not best answer but all we have until we have a fixed version.
