Firmware EEPROM Configuration
I have a question to the above mentioned.
When I click on the menu I get all the values from the printer displayed. When I make a change to one or more values and click "OK" the new values aren't saved to EEPROM. Am I doing something wrong or is that by design (read only)?
  • Enable commands in log and see what gets send. For repetier it is always written. Marlin also shows these if eeprom is disabled so they only get changed until next reset then.
  • OK, will try this evening to look at log output.
    Maybe it would be better for the button to read "Save" instead of "OK".
  • Would be more clear, yes.
  • Quick update: The data is being saved to the printer as it should. I don't understand why it didn't work on my first tries.
