Fan And second extruder will not work
I have an MKS GEN 4 board with DRV8825 drivers and using the repeater firmware I can not get the extruder nozzle fans to work nor can I get the second hot end to heat up I am using the default pins for the second hot end but to no avail, it will not power up the hot end.
i can get a temp reading from it but that's it
