Adding multiple objects, none is being sliced as shown in Object placement.
Like my title says, every time I either add an additional object or cloning one, when I slice them, the end result is not like is seen in the Object replacement screen. Using the Slic3r Prusa edition the object are positioned in the center whilst using the standard Slic3r they occasionally placed on the edge of the printing surface.
This might be irrelevant but I have a prusa i3 clone and all printer settings are properly setup
Thanks!
  • Please check the "Try to preserver model position" checkbox in host slicer tab to preserve positions and not rely on slic3r autoposition (which can not be disabled so we merge objects to one).
  • Faceslap.
    Thanks!
