Host 2.0 crashes...
On Windows 10 Pro, 64bit.
Everytime i slice (with Cura) then goto the print tab i get...
Faulting application name: RepetierHost.exe, version: 1.0.0.0, time stamp: 0x58fb5730
Faulting module name: KERNELBASE.dll, version: 10.0.14393.1066, time stamp: 0x58d9ef32
Exception code: 0x80000003
Fault offset: 0x00000000000c6062
Faulting process id: 0x1fd0
Faulting application start time: 0x01d2c8118a6b2ed1
Faulting application path: C:\Program Files\Repetier-Host\RepetierHost.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 740a7abb-1fcb-4bb6-bd8f-0535a2b0db49
Faulting package full name:
Faulting package-relative application ID:
are there any other software requirements on versions ? opengl, java etc ?
  • Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
    means the error was raise din windows kernel. I can not recreate it from your steps so it is unclear if kernel functions get called wrong or kernel is defect.
    Try in admin cmd.exe
    sfc /scannow
    to check windows integrity to be sure it is correct. Maybe also redownload and install host 2.0.1 to be sure components are also good and reboot windows for what it is worth. Host requires .NET 4.0 and OpenGL. Windows 10 comes even with .NET 4.5.2. For opengl make sure that it shows a graphic card in log and not the generic opengl driver from microsoft - that is known to crash and only implements OpenGL 1.1 (which might be why it crashes).
