angle correction Y tower delta printer
My X-tower is exactly 120 degrees from the Z-tower. However the Y-tower is 119 degrees from the Z-tower.
How do I correct this difference?
  • Set Y angle to 229° so X-Y is 119° and Y-Z 121°.
  • Hi,
    can I change this in eeprom settings?
    If yes how and where.
    What is the difference in eeprom between 'corr diagonal' and 'dealta radius' ?
    Thanks again
  • Yes you can chane them all in eeprom.
    Corr diagonal gets added to diagonal length. Delta radius is the horzontal radius when centered.
