fan PWM frequency
2»
  • edited April 2017
    Yes! I did no print until now, but 244Hz makes PWM usable with my pump !
    The pump starts with S50 and i have good flow between S100 to S255.
    Maybe 500 would be even better, but also with 244 the "pulsing" is gone, so i can use it.
    THANK YOU !
  • News: a 220uF capacitor works for 3 fans in parallel.
    Scope image is quite rough and strange, but the fans start from 15%.
  • Hi
    yes 2 years i know , i guess for other new user ....
    my system powered with 24 volt , my fan is 12 volt  25 x 25 x 10 mm .
    i have added to my setup io PWM card , and then the fan could on do on or off .
    changed the fan control to PWM .
    problem solved
