Dry Run Gcode
Looks like the only way to invoke dry run is through the LCD since I can't find it ;https://github.com/repetier/Repetier-Firmware/blob/development/src/ArduinoAVR/Repetier/Repetier.ino.  Can we get a way to invoke it via gcode?
  • M111 can set debug mode. Value 8 is dry run, Add it to your debug level to get dry run.
  • Awesome, thank you! Looks like m111 isnt in the repetier.ino file. Should I submit an issue for it?
  • Oops, ok I think I remember to add it :-)
