Autolevel a little of
After getting the auto level command to work, the printer finally started calibrating. But for some reason instead of probing 3 points at the edge of the build plate it probed the very left the very back of the plate and then the probe just went up and down to the same place instead of going to the very left of the build plate. How do i fix this?
  • Check in eeprom the probe positions. Also upgrading to dev might improve autoleveling or show additional error messages.
  • What should the probe positions be?
  • Where you can reach them including offset and maximumize area to reduce error.
