Auto tune steps per jam signal
Hi all, I am currently in the process of adding my sparklab filament tracking to my printer and was just wondering why there is no auto tune for the steps per jam signal yet.
It could be pretty much like the auto tune for temperature - starting with a very slow and safe speed and increase extruder speed until steps per jam signal shoots off.
Should not be too difficult, right?
Thank you for the great work so far!
  • It is not that easy as you do not get the required data afterwards. The theory what is needed is quite simple but implementation without using too much ram is the hard part. Nonetheless at some time it will come.
  • Or maybe it is easier to implement as a wizard in repetier server. I was about to buy pro anyway ;)
  • I guess server would be similar in complexity but the solution would be easier to use.
