M106 Command Timing
I am using the 0.92 version of the Firmware.
I have connected a laser diode to D8 on the Ramps 1.4 board.  To control the laser I am using M106 Sxxx for 8 bit control of the laser diode.
My problem is that I can see the fan control g code command M106 is sent and processed by the firmware even though a G1 move command may still be running.  How can I keep the G1 move commands in sync with the M106 commands from a process perspective?
Lindsey
